MT 1 Year Review (Pirelli P-Zeros vs Michelin Pilot Super Sports)
Very favorable review of the 2015 R. No major problems. After changing the tires for PSS the guy said the car is entirely a different beast. Also echoes my thoughts that even after 1 year of ownership the car still looks amazing whereas with other cars I find I get bored of them pretty quick.
Jaguar F-Type Review - Long-Term Verdict - Motor Trend
Good to hear. They seem to be having better luck than Edmunds. Their R coupe has had the peeling paddles, trunk lid separation, and driver seat wear.
I have never owned a Jaguar before will be interesting to see how the little things hold up long term. The mechanicals have been pretty bulletproof so far, I tend to beat the snot out of my cars.
MC
2015 Jaguar F-type R Coupe
1996 Acura NSX-T
1995 Mazda Miata #34
2010 Cadillac Escalade
MC
1996 Acura NSX-T
Completely agree.
I was considering switching to the AWD model. But since I put on the Michelin PSS, the car is transformed. Very predictable, much more linear in loss of traction which makes the car very controllable and easy to drive.
At this point I really enjoy the RWD and find myself able to use the performance of the R.
I have the 340 coupe running on Gyrodynes fitted with Pirellis. As I discovered earlier this week it is entirely possible to unstick the rear tyres when accelerating through a bend in 2nd. Dry road, sunny, air temperature ~25C.
Which makes me wonder if JLR got an OEM version for a really good price, as previously I would have said P-Zeros were some of the stickier tyres I've had...
Yep, agree, it's a fairly reasonable bet that the reason we have the P-Zeros isn't because Jaguar engineers felt they were the very best tire or best price/performance combination available to them, but because there's a beneficial deal in place between Jaguar and Pirelli which helps ensure a future aftermarket business for Pirelli. It would not surprise me if the tires fitted at the factory were deeply discounted or even close to free for the simple r I'd suspect that the majority of tire replacements will simply replace what was there as the OEM tire. Good business for Pirelli and Jaguar, but maybe not so great for owners as they are not necessarily seeing the very best of the car if has the P Zeros fitted.
I'd also be willing to bet that as good as the reviews were for the car when it was released, they would have been even better if Jaguar had fitted a better tire from the factory. I've yet to see a single owner who has made the switch from the P Zero to the PSS report anything other than a big upgrade.
After that MT review I really want to get my tires switched out now. Only at 6k miles so I'm guessing the pirelli's still have a bit of life in them.
Then why are the PSSs showing better track times? (on second thought, one could chalk that off to track conditions).
The P-Zeros have a lower wear rating (220), suggesting that they are stickier than the PSS (300), but yes, the reliability of that rating system is questionable, at best. There must be something else about their construction driving the nearly universal perception that the PSS works better on the F-Type.
From Discount Tire:
The treadwear grade is a comparative rating based on the wear of a tire when tested carefully under controlled conditions. For example the useful tread on a tire graded 400 should last twice as long as a tire graded 200. However, another tire manufacturer may grade a comparable design 300, so a grade of 150 would last just half as long under their grading scheme. The lesson learned is to not use one manufacturer's grade versus the other, but instead to compare tire grades within a given brand. Actual treadwear performance can vary tremendously according to the tire's real-world use. Variations in driving habits, service practices (most importantly air pressure maintenance), road conditions and climate affect tire life.
And more detail from Tire Rack:
Treadwear Grades
UTQG Treadwear Grades are based on actual road use in which the test tire is run in a vehicle convoy along with standardized Course Monitoring Tires. The vehicle repeatedly runs a prescribed 400-mile test loop in West Texas for a total of 7,200 miles. The vehicle can have its alignment set, air pressure checked and tires rotated every 800 miles. The test tire's and the Monitoring Tire's wear are measured during and at the conclusion of the test. The tire manufacturers then assign a Treadwear Grade based on the observed wear rates. The Course Monitoring Tire is assigned a grade and the test tire receives a grade indicating its relative treadwear. A grade of 100 would indicate that the tire tread would last as long as the test tire, 200 would indicate the tread would last twice as long, 300 would indicate three times as long, etc.
The problem with UTQG Treadwear Grades is that they are open to some interpretation on the part of the tire manufacturer because they are assigned after the tire has only experienced a little treadwear as it runs the 7,200 miles. This means that the tire manufacturers need to extrapolate their raw wear data when they are assigning Treadwear Grades, and that their grades can to some extent reflect how conservative or optimistic their marketing department is. Typically, comparing the Treadwear Grades of tire lines within a single brand is somewhat helpful, while attempting to compare the grades between different brands is not as helpful.
BierNut (07-03-2015)
It is a very common misconception that treadwear rating can be compared from one brand to another, it simply cannot. The only thing a treadwear rating is good for is for comparing tires of the same brand.
From Discount Tire:
Treadwear Grades
From Discount Tire:
Treadwear Grades
I made the switch over to Conti Xtreme DW (due to Mich PSS being on back order a few months ago). I am very pleased with ride quality and the grip on both dry and wet. Driving in the wet with the Conti's is amazing in terms of how confident I feel at highways speeds compared to the Pirellis.
I just the latest updates from Edmunds...the problems must be minor enough because the guy still seems very happy with the car.
