Much to my surprise
Had my wheels off my R today for ceramic etc...
In any case, while the wheels are off my plan is to put a protectant on the plastics in the wheel wells to make them easier to clean day-to-day and whatnot. Much to my surprise only the front wheel wells are lined with a plastic material. The back ones have some sort of non-plastic deadening martial I gather.
Not entirely sure, but that material in the back wheel wells looks like it will be a dirt build up nightmare over time? What has been your guys' experience with that material? Does it get really dirty? Is there some sort of preferred product to be proactively using on that material in order to contribute towards it staying cleaner day-to-day over time?
I might be the best person to answer that, seemingly everything is failing of age on my 2015 R, but the reader wheel liner, inside and out, is perfect.
Nothing special about cleaning them, they are like the tread of your tires, they are supposed to get dirty. Rinse them with a hose every car wash, brush them with cat soap if so inclined.
The inner can trap a lot of dirts, you can loosen them and hose away once in a while.
the entire rocker area is hollow, you can hose from one end and see the water and dirt coming out the other.
I'm interested in what other things are failing due to age on your '15. What are some of the sore spots?
Sagging head liner
sagging sun visor liner
sticky buttons and plastic pieces(almost all of them)
Glue lifting on some leather pieces, notably some spots on the dash, and the vertical leather piece by the grab handle
stuck fuel injectors
torn ball joints (suspension, all of them)
disintegrating shock mount bushings
torn spring insulators
leaking pinion seal
failing headlight coating inside and out
That’s about it! To the cars credit, i have close to 0 info on previous caresmanship(is that even a word?), and i park the car outdoor.
edit: and the plastic pipes!! No evidence of it bursting thankfully, but it was at the very least starting to go, slow but steady coolant loss, dropped all these craps with metal ones during fuel injector replacement.
and the trunk cover pins on the tail gate, one of them fell out of the hole.
If I’m being honest the car was most likely garaged most of the time, without revealing too much details, the car was sold by McLaren Palm beach and was serviced there, the guy i bought it from was also very well off.
I’m leaning toward questionable material choice by Jaguar and Sun exposure both contributed to the issue, and I’m not blaming them, these issues aren’t unheard of and one can find them in other makes of any price range, bio degradable wiring and bushing? Rodents love them, and i won’t be surprised if the glues were yummy too.
I’m very grateful that the actual leather used is of high quality and still feels supple and new at 10 years of age!(save some spots on the dash).
Had my 2015 since December. Its my daily driver so I've needed it to be reliable and so far it has been. The only issue is the sticky buttons, but that hasn't bothered me enough to try to fix yet. I'm expecting to have to replace the plastic coolant piping but haven't been brave enough to dive in.
Atipical (06-05-2024)
The computer says I'm getting almost 30mpg too. I think that's a bit higher than reality,
If you are cruisin' on a highway, the dash can show about 30 mpg, but keep the revs up and you will drop by 10 MPG, easy.
![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
Ichi Ban (06-12-2024)
paydase
08-23-2016 03:45 AM
