Muted Exhaust Mystery
2017 F-Type R Coupe daily driver 30k miles
I’m still trying to track down why after warm up, my exhaust sound has become somewhat more muted than than it used to be. I always drive in dynamic mode with sport engaged on the shifter, and a large percentage of the time I’m using the paddle shifters.
I have not had any of the reported exhaust patches applied which have been discussed in other threads that take away pops and crackles. I still can modulate as many machine gun type crackles at will.
I’ve verified that exhaust valves, that can be seen through the tailpipes, are opening and closing correctly, and when I close them, there is a huge difference in how much the exhaust note is muted.
The Mystery is this: When I’m idling and reving the engine in the driveway (with my door open)where I can really hear the exhaust, I’ve noticed that there seems to be an additional stage of open/close muting besides the valves in the back. Example: I’m idling in full dynamic mode...now I use the switch to take it out of dynamic, and of course as it should, the exhaust button light goes out telling me the valves are closed..the sound is very muted. Next is the interesting part. I press the exhaust button and open up the valves, the note becomes less muted. (Note: I’m still not in dynamic mode) Now, when I engage dynamic mode switch (remember, the valves are already open) there is a secondary increase in volume and depth of the exhaust note. So my question is, what else in the exhaust chain is opening up? If I can ascertain this, perhaps I can identify why my exhaust is sound more muted than before. Maybe it’s something to do with whatever this secondary stage thing is? Also, or... could it be the catalytic convertors getting clogged or starting to go bad? I have had no codes, or smoke from tailpipes, but maybe they are clogged enough to change the exhaust sound??
CORRECTION: See my Post response to SCM which says: "your right in that in Dynamic mode the exhaust light is on (lighted), Dynamic mode off and everything is off. (I'll have to modify my original post) Here's what I didn'tknow until I just double checked. With Dynamic mode OFF, if I then just hit the muffler switch(with lights up), only the passenger side valve opens to add a little more sound (as designed I guess) When I activate Dynamic mode, BOTH sides are open, and so that must be the sound difference I'm hearing between Dynamic + exhaust switch on... and Dynamicoff + exhaust switch on. So now the only part of my question that is still valid is whether the CATs starting to get clogged will alter and slightly mute the overall sound, making it more muted than it was when the car has less miles on it?
I really apologize for the long and very clumsy explanation of what I’m hearing, but I miss my exhaust sound when the car was newer.
CRS
CRS
The Mystery is this: When I’m idling and reving the engine in the driveway (with my door open)where I can really hear the exhaust, I’ve noticed that there seems to be an additional stage of open/close muting besides the valves in the back. Example: I’m idling in full dynamic mode...now I use the switch to take it out of dynamic, and of course as it should, the button lights up telling me the valves are closed..the sound is very muted. Next is the interesting part. I press the exhaust button and open up the valves, the note becomes less muted. (Note: I’m still not in dynamic mode) Now, when I engage dynamic mode switch (remember, the valves are already open) there is a secondary increase in volume and depth of the exhaust note. So my question is, what else in the exhaust chain is opening up? If I can ascertain this, perhaps I can identify why my exhaust is sound more muted than before. Maybe it’s something to do with whatever this secondary stage thing is? Also, or... could it be the catalytic convertors getting clogged or starting to go bad? I have had no codes, or smoke from tailpipes, but maybe they are clogged enough to change the exhaust sound??
In mine, when idling, switching dynamic on lights the exhaust switch and opens the valves so you get the grumble. out of dynamic mode with the switch on doesn't open the valves - the valves don't actually start opening until around 1,500 rpm, you can definitely hear the difference if you then switch dynamic back on. Hold the revs above 1,500 and play with the exhaust switch to see how it behaves.
As I mentioned, other MYs are different, some open the valves at idle out of dynamic mode, these cars have had many subtle changes throught he build years!
My MY18 doesn't work as you describe, so different MYs have different characteristics.
The partially muted symptoms I'm describing are while I'm in full dynamic mode, with shifter set to sport. The setting I've use pretty much 100% of the time for the 3.5 years I've driven the car.
I've checked multiple times (while in full dynamic mode) by pulling over to the side of the road, putting the car in park and I observe both valves fully open while idling. I've checked a couple time because I could swear that they were partially closed by what I perceive as a more muted than normal sound...but each time they are fully open.
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
BTW : MY17 R Coupe. Thanks for any insight Unhinged
CRS
Exhaust valves are not designed to operate independently as already mentioned. The fact the your car can means one of the valves is starting to stick. I suspect the different modes(dynamic vs non-dynamic with exhaust on) probably create similar but slightly different vacuum pressures that may not be high enough to open the valves fully. The sticky valve requiring higher pressure than an non-Sticky valve to open so hence is affected first once the pressure becomes suboptimal. Also would explain partial opening at times . A leak in the vacuum pipe or fitting coming loose may be the issue in theory. And of course fixing the sticky valve too
CRS
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
CRS 123 (01-11-2021)
I think your MY uses engine vacuum rather than the electric vacuum pump. This is from 2013...
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
Simran Singh Randhawa
12-14-2016 01:06 PM
