MY2019 F-Type R oil overfilled
Do these cars not have a standard drain plug on the oil pan? I'd check before I leave the dealership. However, if home already, I'd just get under there, remove the plug, and drain some oil. No way would I waste time and risk damage by towing it. I'd definitely take a photo and send to dealership though. I use race ramps to lift the car.
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
Removing that undertray helps your car go faster. I dump 5 lbs of road grit out of it every year.
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
Now, it you ever feel the desire to access the engine air filters....
![Icon Brr](https://www.jaguarforums.com/forum/images/smilies/icon_brr.gif)
ferrral (10-29-2021)
Received 3,209 Likes
My learnings and views after changing the oil at least a dozen times on my XFR and F-Type:
- Until a couple of years ago I used the sump plug removal method to drain the old oil as I wasn't convinced that the top extraction tube method removed as much of the old oil.
- After a fair bit of research I worked out that both methods remove as near as dammit to the same amount of old oil, as both the bottom of the sump plug hole (it sits on the side of the sump) and the bottom of the extraction tube sit the same height above the bottom of the sump pan (around 5 mm).
- I also discovered that most (but not all) dealerships use the top extraction tube method.
- When I used the sump plug method on the F-Type I removed both the front (main) undertray and the secondary smaller undertray behind it, as it is that secondary tray which covers the sump plug. It wasn't until much later I discovered that you don't need to remove the front undertray with it's eleventy million bolts and screws, you only need to remove the secondary undertray as Carbuff2 says.
- The top extraction tube method is so much easier, quicker and cleaner that I will never go back to the sump plug method.
- However it is a good idea to remove the undertrays once in a while to inspect everything under there for leaks, rattles, loose bolts etc.
#28
had my dealer change oil about 500 miles ago , aprox a month later i checked oil level and it said over fill let the car sit for a week checked again and the oil level was perfect , took the car out for a tree hundred mile drive , let the car sit a few days checked again and it said overfill dealer said the added 8nqts b said they put 8 qts. at oil change., next step took it back they said the took 1/2 qt out now the scale is about 3/4 to full any ideas
scm (10-30-2021)
