I just got done installing a meth injection system. (Thanks Therock88!!!, you are the best) While I was was tapping into the MAP sensor in the back of the engine, I noticed a black plastic tube with pink lines on it. One end seems to go no where and the other end goes on top of the transmission tunnel. I noticed some of the plastic vacuum lines were brittle and cracked. I replaced what I could but have no idea where this black/pink one goes.
The black small plastic tube is supposed to go to nowhere...It is the transmission vent tube...It sort of hangs off of the Symposer(which I removed ) bracket. The other end attaches to the top of the ZF tranny.
