Nav screen flickering
First problem with my V8S. A few days ago the nav screen was flickering when I got in the car. All functions work properly (nav, audio, phone etc.) but the screens was nearly unreadable and then went black. Next startup, no problem. Since then it is bad more times than not. I haven't had time to get the car to the dealer yet and am hoping that it is just a connector but this is not making it any easier to defend my buying decision to those that question Jags reliability record.
Update: the dealer, in conjunction with Jaguar, determined that the screen is defective and needs replacing. Sounds easy enough other than the fact that it has been nearly a month since the "rush" order was placed and still no idea when it will be available. I know that they are busy building cars and inventories are tight, but you would think that they would want to have the cars on the road working right.
I wanted to update all of you on the nav screen issue. It took Jaguar nearly six weeks to get the replacement to the dealer, but all is up and functioning properly.
I had made a comment in someone else's post that I thought that the car was louder than it needed to be while in standard mode. The dealer was kind enough to give me their demo V8S while mine was in the the shop and I noticed that it was substantially quieter than mine. Upon inspection, it was discovered that the vacuum hose that operates the butterflies was never attached. its nice to know that the switch actually does something now.
Another interesting point is that I had specified Sirius when I ordered the car, but it was missed by the dealer. Jaguar confirmed that all cars are pre-wired for sat radio but we have been informed that there is no way to add the factory set-up after the fact. Its interesting as the back of the screen (that was replaced) has a row of digital inputs and there is clearly an open one that I would assume is for the sat tuner. It would make sense that the system would be a small box of some type that should be easy to plug in. Not a deal breaker, but just an FYI in case someone was hoping to add it at a later date.
Other than that, I am very much enjoying the car and it continues to attract attention wherever I take it.
Cheers!
Cheers!
Cheers!
Cheers!
Finbarr1975
09-16-2023 02:52 PM
