Navigatio Audio
I think u have it correct. There's an adjustment hidden somewhere in the menu...or during navigation, when the voice is saying something, use the volume knob...
I can confirm this. When you have a route created, just keep hitting the little speaker icon at the top and it will say the next step again and again each time. When it does, you can raise the volume to your desired level. It will stay there until you mess with the volume again when nav is actively "talking".
Not in the car at the moment, but it can be completely disabled, and increasing the volume will of course, do nothing!
From the navigation map screen, press the Nav Menu button, there should be a button on the next screen that says Route Voice Guidance. It will have a red line thru it if deactivated. No red line if activated.
Also, from the Main Menu home screen, press the Setup button on the left, press the System button, then the Volume Presets button and be sure the volume on the navigation slide bar is set some number of points higher, relative to the other audio functions that it may need to over ride.
