Need advise, what the best paint protection
Hi guys,
I have my car now for just about two months. Yesterday when looking over the car, I noticed my first paint chip. It's a super tiny chip located at the front center area of the hood. I asked myself, how did this happen. No chips on the bumper area, only the one chip on the hood. As small as it is, it's an eye sore to me. So I need to take immediate action to protect the car's paint job.
Which procedure is better to stop paint chipping from occuring, doing the Ceramic Pro coating or doing EXPEL type application on the car.
I'm leasing the car. I wish to protect it but I don't want to go ***** to the walls with spendature on a leased car.
Thanks for your input.
You confirmed what I suspected with cost, EXPEL being the more expensive of the two. Can you and anyone else guy some approx prices for good coverage all over the critical areas of the car.
Thank you.
Ceramic pro is great to protect the finish, make it extremely easy to clean, and to an extent protect against rock chips but some will make it though. I've noticed two hit on the hood that would have resulted in rock chips but I was able to remove the mark with a microfiber.
My detailer was very clear about that, but at the same time his car has been driven thousands of highway miles and doesn't have a single chip, but EXPEL is an actual clear bra, so its going to be much stronger against chips.
I just went with Ceramic Pro as a step up from OptiCoat Pro , and the fact it really does a great job protecting the paint finish and offers some chip protection. If you drive a lot of highway miles or just have bad roads XPEL is a great way to go in at least the area more prone to chipping.
Last, for a lease, which would you guys choose, because I'm definitely going to do one or the other.
My blood pressure was jacked up over the tiny stone chip.
I'm going to be a wise *** here. If you want your car to stay looking perfect, don't drive it. Despite your best efforts you will get a chip or a door ding. The more you drive it, the more chances of getting dings. Just nothing you can do about it. That said, Xpel (or similar) over the entire car at several thousand $ will likely give you the best protection. Maybe 2 layers.
I always buy used so that I don't have the anguish of the first ding nor the feeling of my wallet flying away by the first year depreciation. Both are going to happen.
Ceramic Pro I believe is in the $1000 dollar range.
Yes ... ?
Originally Posted by Ubad2
Your saying $2000 to $3000 dollar range to put clear bra film on the critical areas of the car . Wow !!!
Yes ... ?
Yes ... ?
Ceramic coatings are for hydrophobicity and the ease of getting bugs, tar, water marks off. They will not protect against rock chips.
You’re as bad as I am, rock chips drive me insane but I don't want to lose that depth and gloss of the paint after a correction. I'll loose sleep over a chip LOL
The Ceramic Pro requires a full pant correction and details before the car is coated so the cost can vary from 1k-3k depending on the level of protection you want. Keep in mind that covers everything paint, plastic, wheels, glass, calipers, the entire interior. Now it's strong stuff, I was shocked buy some of the videos on the internet. If an object had enough energy to make though the coating and cause a dent it would probably chip, it's not 100% chip protection but is pretty darn good, and the look of the paint is second to none. Plus the ease the easiest car wash possible.
With the clear bras, you get better maybe even guaranteed protection as it also absorbs the energy of the impact as its thicker and . My concern was losing gloss and depth as you can see it if you look. It looks good but it’s also not going to look like a freshly corrected paint finish IMHO. I'm not sure of the price but you could always do combination.
Xpel on the front bumper/hood and ceramic pro the rest of it.
It's really a tradeoff, great finish with good chip protection, or very good chip protection with a slight loss of gloss and depth.
Talk to a professional detail shop, and they should have examples of both on customer cars in the shop. These guys know their stuff when it comes to paint and protection.
We've come a long way in paint protection options in the past couple of years.
No matter what you end up doing, don't buy it from a dealer.
Personally, I believe in clear film protection for the front. I always get it done at the workshop I trust. Keep in mind, if you live in a hot climate, like Texas, it will crack and will have to be peeled and re-applied every 5 years or so.
Many years ago I had dealer do this. Not only they charged premium over what it would normally should cost, the ******* that installed it cut it on the actual hood, so when it was re-applied I found cut lines in the paint.... and the dealer wouldn't own up to it.
an awful lot of unbalanced info being shared here...
Paint Protection Films (PPF) like Xpel Ultimate (NOT EXPEL) or Suntek does exactly as it implies. The layer of protective elastomeric film generally protects the paint against minor road gravel and debris thrown up against your car. You can get a partial hood and front end done for $1500, full hood and full front end done for around $2000, or the entire car for $3500-4500. Short of doing the entire car which most feel a bit unnecessary, you can add surfaces like the rear Rocker Panels and/or Rear Spoiler to the front end and you should expect to spend somewhere between $2000 and $3000. For your concerns on a leased car, the front end options alone should be more than adequate.
Ceramic coatings and the various other formulated coatings are NOT promoted to protect against rock chips! Period! They are designed to bring out more depth in the paint, and increase the gloss level of the paint. Such Coatings also make water sheet of your car, typically making it easier to clean and dry. Depending on the installer or applicator, Ceramic Coatings can go from $1000 to $3000.
While it is quite common to "Film" part of a car, I've never heard of someone "Coating" part of a car.
Both products will protect the paint against contaminates like bug guts and bird droppings, though either should be washed off as soon as possible because if left untouched for a week, they can and will etch both the Film and/or the Coating.
Based on your concern over the unsightly chip smack in the middle of the hood, it will not be your last. The rake and aerodynamics of the F-Type hood seems to be a magnet for rock chips. Paint Protection Film like Xpel Ultimate should be your solution of choice.
15mm offset spacers, stickier PSS tires, occasional 100++ mph sorties, or just normal for the F-Type. I only have 2 or 3 miniscule blemishes in the wrap from incoming projectiles on the hood.
Do not forget to wrap the entire rocker panel to the front of the rear fender well. My Xpel just in front of the rear tires, after 16k miles, already feels like sand paper. I can only imagine the damage to the paint if that area were not covered. I may have to have the rockers re-covered after 30k miles. The problem may stem from one or more causes:
Must be the spacers!
I have the same area wrapped, and it remains pristine after 19K miles.
I too have PSS tires, I regularly exceed 100 mph, but I have yet to install my spacers.
I do stick to well paved roads... Could that be the difference?
Just had the gold package Ceramic Pro put on mine. Lifetime warranty, interior, wheels, calipers. Just a "tune up" once a year to keep warranty in effect. Cost was $1800. Well worth every penny. This stuff is awesome! Shines like crazy, wipe a coffee spill right off the leather, brake dust comes off with water.
You have commented about this several times.
The spacers could well be the issue.
