Need help with brake fluid change
Old 09-03-2023, 07:56 PM
randyb's Avatar
Funny, both a Jag tech and a youtube video says it does and I did this on my XK twice and it worked perfectly. Brake pedal was rock hard.
Old 09-04-2023, 03:23 PM
vkt's Avatar
vkt
vkt is offline
I finally finished the brake job. I had to purchase a computer on Amazon and interface it with the OBDII port, then choose ABS bleed. It started with telling me to open the bleeder valves in the rear left first, then the front left. Those seem to just be standard steps that can be skipped, though. The ABS didn't activate until the front right. Then I opened the bleeder valve and the ABS module burped a LOT of air out through the front right. This is on a LHD car. Pedal is rock hard again.
The following 3 users liked this post by vkt:
Carbuff2 (09-04-2023), DJS (09-04-2023), scm (09-04-2023)
Old 09-04-2023, 06:09 PM
Moniker's Avatar
Good that you got it sorted out. Would you share waht computer tool you used
Old 09-05-2023, 08:58 AM
clubairth1's Avatar
Received 2,349 Likes on 1,849 Posts
Correct! You MUST activate the ABS valves electrically or you are NOT changing the fluid trapped in the ABS reservoir. Regardless how hard you brake pedal is. That has zero to do with the ABS!
Old 09-05-2023, 07:03 PM
vkt's Avatar
vkt
vkt is offline
Amazon Amazon
Gearhead01 (09-06-2023)
Old 09-05-2023, 08:12 PM
Moniker's Avatar
Old 09-11-2023, 08:34 AM
Simonusa0's Avatar
Yes dealers sometimes do it earlier than necessary for revenue purposes, but whether or not you know the following, your comment may be misleading or misinterpreted to the uninformed.
Brake fluid is not 'set for life' as it is hygroscopic thus absorbs moisture over time and them corrodes the brake line system from the inside. Also if it then gets very hot (eg track use) it could will affect proper breaking if the water in it boils to vapor. Cheap >$15 electronic fluid testers are available to determine water content of the brake fluid and whether it should be changes
Brake fluid moisture tester
So this is why brake fluid needs to be flushed and exchanged with new after a few years (e.g every 4 or 5 years).
  #28
Old 09-12-2023, 07:16 AM
clubairth1's Avatar
Hey thanks for posting that!
You finally convinced me to get a brake fluid moisture tester as they are very cheap!
Mine is different but they all appear to operate the same way.
I also don't know how important the three different settings are either? DOT3, DOT4 and the newer DOT5.1 fluids.
Here is the one I got for about $16 on line.
You have to love how they mangle the English titles too!
Oh well at least they spelled it correctly on the tester itself!
One thing I have NOT done yet it test it on the bench with known levels of water in the brake fluid. I have read some reviews that these meters don't really work or don't work very well?
Anyone test theirs?
jlewis10
07-26-2021 09:19 AM
EdG
10-21-2020 11:43 AM
alynmurray
10-30-2016 06:49 AM
Vector
03-18-2013 12:41 AM
govatos
07-16-2010 04:30 PM
Quick Reply: Need help with brake fluid change
