In the process of reinstalling everything from my stage 3 tune nightmare story, I broke this clip. For now it's held in ok, but I would like to replace it. I am assuming this is part of the fuel line/fuel system, but cannot find a link/part number for it. I also assume you'd have to replace the entire hose, not just the clip itself from what I can tell. If anyone has an idea what this is called/part number, it would be a appreciated assist. This one sits on the drivers side of the engine bay.
I'd be installing a zip tie around the upper hose, then another zip[ tie around the 'broken' one.
Got a farther-back view of the hoses so that we know where they are?
Here is a better picture. I think it is part of the emissions system or some sort of vacuum line. It is not coming loose, so even though it is broken, it is holding, but I would still like to replace it.
Some parts stores carry nylon tube and connector repair kits. You might be able to find one and remove the clip to use on your line. As far as I know the dealer will only sell the full vacuum harness.
the good news is it’s holding fine. Seems like just a vacuum hose. For now I’ll just leave it. But eventually want to replace it.
