Need Help Locating Power Source in Drivers Footwell ONLY WHEN KEY ON
I am trying to get a Radenso RC M custom mount radar detector set up in my 2017 Type SVR and I have all the cables run there, but for the life of me cannot find a hot 12 volt power source there that is only on when they key is on. I have tried all of the cables running to the fuse box, most or many of the multiple plug connectors in the area, etc. Has anyone else wired one of these up or found a keyed power source in this area for any other reason? I have searched this forum to no avail plus googled my butt off online. So far no luck. Any ideas anyone?
bhdau1 (05-09-2022)
Thank you! That is close enough I think that the power cord to the head unit will reach it as it is just on the other side of the firewall. I may just need to drill another hole there and grommet it and should be good to go. The wire from the front radar head is run thru this same area. Now however I am dealing with another issue totally unrelated, my freaking hood wont open. Pull the lever and nothing happens. Have had my wife and I push down on hood while pulling lever, no good. I took the drievrs side front wheel off and the fender liner out to see is there is an access panel and there is not. Not sure what the hell Jaguar was thinking on this one. The only thing I can figure is if I removed both fender liners and both front wheels I could remove the three bolts per side on the hinge that are accessible this way. That still doesn't get the hood latches undone but might allow me to pivot the hood up some to access them. I think as I am still under warranty for stuff like this Ill just let Jaguar handle it. The only issue for that is the earliest appointment is the 6th of next month!
The central cig lighter might be a good idea if I can figure out how to remove all the trim around it without breaking things. I am already running two wires along the top of the windshield just tucked up in the headliner and behind the a-pillar cover down to the drivers footwell area for the radar control unit and GPS antenna so its pretty crowded to tap the mirror power. The other issue with the mirror power is the power cord for the head unit is not very long so I would have to splice in more wire which I am trying to avoid. Thank you for the cig lighter suggestion though!
It's under the carpet, under the floor, towards the front of the passenger footwell. I couldn't find it the first time I looked as I assumed it was on the side somewhere.
I've connected to a fuse there to provide power to an aftermarket wireless relay, which shuts of the active exhaust pump so the exhaust valves are always open. I imagine that's switched, but I don't know if I checked that.
The Rock88 and takeapieandrun, Thank you for the suggestions. I just ordered a package of the mini fuse taps on Ebay that should work in either location you guys have given me. Pretty cool little taps if they work as described. I probably could have just rigged the wire into the fuse with some stripped and twisted bare wire but this looks like it might be a little easier and cleaner.
Thx, Brent Day
Thx, Brent Day
Fast Cat
10-22-2014 10:25 AM
julio1
06-11-2008 04:48 AM
