New F-Type 02/12/19
#141
I had no idea they dropped the 6cyl outside the US:
https://www.carthrottle.com/post/no-...ng-without-it/
#142
Received 3,209 Likes
UK get the lo-po V8 but not the V6.
Oz gets the same as the US (V6 but no lo-po V8).
It is completely and utterly all over the shop with zero logic that I can see, especially as the US is the home of the V8 and Oz has loved V8s as well forever (think Holden vs Ford and Bathurst).
#143
You get the V6 but you don't get the lo-po 444 hp V8.
I wish they had not dropped the V6 here, if that meant they would also keep the manual. Even better if they would start offering a manual with the low power V8.
#144
If they had a small bore, high revving V8 I'd be on to it like a fat kid on a cupcake. Add manual...
https://giphy.com/gifs/Zk9mW5OmXTz9e/html5
#145
#146
#147
I think all this is in the line to make economies, as hard time (Brexit) lies ahead. And also they want to liquidate their gasoil engine stock before the electric time. And like this motors are mostly software configurated on power, they can adapt the hp in a certain range. So may be that some engines sold outside Europe are not in line with the Euro Co2 norm. Anyway all V6 and V8 from 2020 are Euronorm 6d temp, and out of norm from 1/9/19. So they should arrive to construct the 2021 V8 in the Euronorm 6d (without temp) to make immatriculation possible in Europe. My 2020 has already a gasoil particle filter integrated, but is a temp. Hard time coming for muscle cars.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
#148
"New to the range is the 450hp V8, which is based on the supercharged 5.0-litre V8 fitted to the old car. It generates 580Nm of torque from 2,500rpm which is enough to get the car from 0-62mph in just 4.4 seconds and onto a top speed of 177mph. You can have the car either with two-wheel drive, for a more challenging drive, or with four-wheel drive which allows the car to get all its power down with minimal fuss, irrelevant of what the weather is doing. Whether you choose two or four-wheel drive, you also get an electronic rear differential which allows the car to send power to whichever tyre has the most grip and, like all F-Types, an eight-speed automatic gearbox."
The XKR had 475hp and 600Nm. The current v6S is a better car to drive as a sports car and much more responsive, but the transmission will make a lot of difference (transmission was probably the most noticeable improvement between the XKR and the F Type) and also traction is vastly improved.
#149
This is from carwow:
DAve
#150
Uncle Fishbits (12-13-2019)
#151
Yeah I have one of those on mine, the car is wicked fast. The only difference I think though is that with the 8 you'd get a sweeter note (personally I am not as much a fan of the 5 litre note, I preferred the 4.2 but still...) and also someone recently pointed out that due to the engine running hotter, the pulley and tune cars arent suited to track days.
polarisnavyxj
06-07-2016 05:11 PM
