New Michelin Pilot Sport 4 S news
Burt Gummer (02-26-2017)
There will be no problem at all running 265/305's with no spacers on OEM wheels.
HalcyonDays (02-27-2017)
#28
#30
Does the addition of Velocity AP lowering springs change your answer?
#31
Regardless of the springs, the car bottoms out at exactly the same height. 295's with 17mm spacers do not cause a problem, but 305's with 15mm spacers do. This means that 17mm extension works, but 20mm of extension does not. Some might be running on 305's with 17mm spacers and have not experienced any problems since they have not bottomed out yet. Bottoming out is progressively more likely as you lower the car (with springs).
#32
#33
Regarding tire sizes and wheel offsets that will fit without issue, here is my thread:
https://www.jaguarforums.com/forum/f...ghlight=rohana
I run a 325 tire out back at the track and even on launch they don't rub / cut / etc.
#34
#35
You seem to have tried a number of combinations... Does the lip of the quarter panel simply rub the tire, or does is cut the tire?
Would turning this lip up slightly, at the 1:30 and 10:30 positions you indicated previously, correct the problem with 17mm spacers and 305 PSS, which would appear to conflict be 2 silly mm.
#36
#37
I already have the 17mm anodized black spacers from the group buy so will definitely be adding those and the new 4s tires in EOM sizes when they are actually in stock.
Same with powdercoating Gyrodynes all black.
Love the look of wider tires, but supremely hate the chance of scraping. 295 it is!
JgaXkr (03-04-2017)
#38
Received 3,226 Likes
The following 8 users liked this post by OzXFR:
amr42 (03-08-2017),
Burt Gummer (03-09-2017),
DJS (03-09-2017),
jaguny (03-06-2017),
malbec (03-07-2017),
and 3 others liked this post.
#39
#40
