new owner, saying hi
I sold my Audi R8 (2010 V10) and bought an FType V8S.
Had the car for 400 miles now, over the span of two weeks. Really only drive on weekends.
Black cyclone wheels, black exterior, red interior, maxed out (I didn't build it, but took advantage that someone else did and then fell through on the sale).
I probably would have put on the carbon package (not the wheels, but the hoops and the side vent thing) - but I like mine enough as it is.
Car is currently going back to the dealer as there are paint issues in the body panel joints by the rear wheels.
And then yesterday something kicked up on the road and messed up the driver's side side skirt.
I've had a bunch of cars and never have I run into issues like that immediately - but in the end, all I care about is the sound.
Other than that, the car is just fantastic.
Did you complain to the dealer about it, and/or do anything to get it fixed?
Mine looks like it had bubbles, and then they got pushed away, leaving little white circles in the black paint (assuming the underlying plastic is white).
At first I thought it was wax in the joint, or teflon tape from shipping - so I picked at it, and then saw I was making it worse and it was the paint.
Even went so far as to wonder if it was a (bad) wrap job, but doesn't seem to be.
The rock that kicked up hit the same panel but down lower, and I am not sure if it cracked the plastic, or just put a gouge into it.
I don't know if they take the panel off when fixing the paint issue, if so maybe they can fix the other issue - if not - curious how much the panel costs to fix/replace.
I also had a slight chip in the finish of one of the wheels that they addressed, flawlessly I might add.
Not sure on the other body work that you'll need. I suspect it's cheaper to repair than replace.
So three of us with the issue and all the same color.
Are the other colors a non-issue, or are they not as noticeable?
Something about the color that's goofy? (obviously not actually the color, but the process/paint, different?)
I haven't heard back from the dealer yet on my car - but interesting to see that it is definitely "a thing"
I have the British Racing Green and had the same paint problem on both sides of the car. I took it to the dealer last Monday and got it back last Friday. The dealer sent it to a nearby body shop that specializes in high-end European cars. They do take the bottom panel off and sand/repaint it. It looks like they did a good job.
When I first took in in, the service manager said he had not seen that before. However, we found that they had a black one in the showroom with the same paint problem. Apparently, no one had noticed it.
Below is a picture of mine before it was fixed:
![](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/60289-new-owner-saying-hi-407802912.jpg?dateline=1382979172)
yes, it looks very familiar to what I had on one side in the same exact spot and on the other side it was bubbly throughout the seam.
Both sides needed to be fixed. I'm not sure it I'm glad it wasn't just me or if I'm concerned this seems wide spread on these 2 colors. But, why limited to only this area of the car I wonder too.
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
Andrew Fanshawe
09-14-2015 07:40 PM
