Nipples
Are you talking about the pivot pin on the shelf? If so, the whole shelf needs to be replaced. Your best bet is to fabricate some kind of replacement pin. I seem to remember that someone on the forum has already done that several moons ago. A sub-forum search might reveal the solution.
I had the same issue and fixed it with a bolt which I then covered with a piece of electrical shrink tubing. Works fine and cost about $1.38.
Sovande, did you remove the panel to effect that repair?
I didn't have to remove anything, I was able to pull the panel out towards the center of the car and slip a bolt through the hole. I have nuts and washers in both sides of the trim piece. On the side in the cargo area I also used a lock washer. It's been that way for about a year and half and seems to be fine.
PaulBarrrera (08-28-2023)
