Nitrogen fill in tires...
What I don't understand is how do you get the tire filled with pure nitrogen. When you mount the tire you have air in there. Then you add nitrogen, but adding nitrogen doesn't get rid of the air that was already in there when the tire was mounted.
So in reality you may by using nitrogen get to a 90% nitrogen fill, versus a 78% nitrogen fill using air to fill the tire. But I don't see how you can get to 100% fill unless you fit the tire inside a vacuum.
Typically they will put green caps on the stems with NO2 embossed on top.
I can't imagine the dealers I have worked with doing that at all, much less for for free. I suspect they would have just changed the caps. I would have tests run to find out for sure.
My two 2014 F-type V8S models both came with the crappy grey plastic valve stem caps. I guess I have to make do with ordinary air in my tires.
Oh well, I have had to replace half of it anyway from dealers dropping my preferred air pressure settings when the car was in for service. And in fact now that I think about it, I replaced all of it in the right rear for a flat repair. Would hate to have three with nitrogen and one with air. At least I don't have to match up the other three now.
Thanks for the reply. I am going to go sulk now, bemoaning the fact that I wasn't given a complimentary nitrogen fill when I bought either of these cars.
Received 2,263 Likes
Exactly. As Norri mentioned, the devil is in the details.
Much like oil and filter discussions, the owner should choose what makes him happiest. The car couldn't care less.
The moisture content in air is of utmost importance in aviation for good solid technical reasons. None of these conditions exist with motor cars.
I think the suggestion that the dealer and not Jaguar being responsible for installing the magic green caps is the most probable scenario. None of the cars I've seen on our local dealer's floor has them.
Received 6,307 Likes
I came across this which amused me at least:
'So: suppose you start with 40 psi air. After some time, the O2 leaks out. Now, 32 psi.
So you refill with air- 8 psi partial pressure, of which about 1.6 psi is O2.
Then that leaks out. You are now at 38.4 psi.
Refill with 1.6 psi of air... of which .3 psi is O2. That leaks out.
Now you are 39.7 psi... pure N2.'
Well, that leaves me out as the State of Maine still has winter-like temperatures - or quite close to; particularly if you factor in the gusts of winds lately - so I guess winter air will have to suffice.
Also, some of us don't have "crappy grey plastic stem caps" or "green caps with NO2" on them....
#28
There is a logical fallacy in the idea that different size molecules
will leak through a permeable solid at the same rate, not the least
of which is the presumption that the tire carcass is in fact permeable
at some rate that is noticable over the period of a year.
If it is permeable and presents paths of different sizes, then molecules
of different sizes will leak at different rates.
Take a sieve with two sizes of openings. Call those sizes 1 and 2, with
2 being the larger.
If you pour a gallon of particles that is size 1 or smaller into the sieve,
the particles can flow through both the size 1 and size 2 openings in
the sieve.
If you pour a gallon of particles that is between size 1 and size 2 into
the sieve, then the particles can only flow through the size 2 openings
while being blocked by the size 1 openings.
Since it is the same volume of particles exiting through a smaller
surface area, it will take longer to flow through.
Size 3 particles won't flow through the sieve at all, even though
the sieve has holes.
I believe that there are benefits to nitrogen in filling tires, particularly
when done at no cost. I would also happily touch up a tire with air
from any old compressor while on the road. The thought being that
the dilution is not significant.
There are cases of tires that have been impossible to balance until
they were dismounted and drained of water.
If a tire starts with nitrogen then there is less chance, even when
diluted with unconditioned air, that significant amounts of moisture
will form.
About the same as waxing a car. The paint is fine, but adding the
wax has benefits.
2 being the larger.
the sieve.
will form.
wax has benefits.
![Icon Mrgreen](https://www.jaguarforums.com/forum/images/smilies/icon_mrgreen.gif)
#31
..... and at which point the leakage rate would drop noticeably if we are to believe the myth. If it were true, there would be no need to create the energy wasting nitrogen machines we see at tire shops.
#32
#33
The plot thickens. Now the dealer would have had to dismount the tires, replace the TPMS equipped rims with special, longer TPMS sensors, change out the air for nitrogen, add the special caps...possibly in a vacuum...and not charge anything for it. Wow.
#35
Yes, I am jesting about this thread. It's interesting that people can get that into what is in their tires or even have an opinion on it at all. I can't find any summer air here in Enumclaw yet, but I still have some equatorial air left. You are lucky you have the nitrogen...
#36
N02 is primarily used in aircraft tires for the simple reason that in the case of a fire or an electrical fault at altitude in the wheel well, if the tire casing is comromised the N02 provides no fuel for the fire, were as 02 would.
Do not use steel stem caps on aluminum stems, the consequent dissimilar metal corrosion will make life difficult in the future.
If moisture content in air for your tires is a concern, then come to Minnestoa in January when it's 25 below and fill your tires. Air that cold is virtually devoid of any water content.
Another member struggling with the rotating TPMS phantom warning problem.
Regards,
White Bear.
Regards,
White Bear.
#37
If moisture content in air for your tires is a concern, then come to Minnestoa in January when it's 25 below and fill your tires. Air that cold is virtually devoid of any water content. ��
Regards,
White Bear.
Regards,
White Bear.
#38
For what it's worth, my dealer has a machine that fills the tires with nitrogen while or after actually sucking out the air, or whatever previous gas was in the tire. I assume that's how nitrogen fills are done.
Tires are delivered to the dealer filled with regular old fashioned UK air. It's the dealer that replaces with nitrogen. No dismounting done, just a drain and fill so to speak.
#39
