No start hard brakes
Spent the day stranded with my first ever issue with my 2015 F-Type V8S. Installed a new battery roadhouse to no avail (old battery tester good) courtesy of an expensive Uber ride. Brake pedal is hard as a rock so working theory now is brake pedal sensor. Towed to shop. Any guesses from the group?
David Meier (06-23-2022)
On my car, if I press the start button without depressing the brake pedal, the ignition comes on in accessory mode, and there's a message in the message center 'Depress Brake Pedal to Start' (something like that). If you get that message, then it doesn't think you're pressing the brake pedal.
kb58 (06-22-2022)
Actually, that's a good first question. @David Meier Can you get into accessory mode?
It is normal for vacuum-assisted power brakes to feel immobile/immovable when the engine is off, after the first pedal 'pump'. My first impulse is to direct your investigation of the No-Start elsewhere.
Does the starter operate at all? Or does the engine turn over, but not 'fire'?
Received 3,226 Likes
Yep, I am one of those who have removed the secondary battery (one or two years ago) and zero problems.
