Non-Performance Modifications/Upgrades
As a new F-Type owner, I am planning on making one or two modifications/upgrades (that have nothing to do with the performance of the car - IOW, solely appearance related). I kind of like the puddle light logo that some have purchased on ebay. That may be one of my first.
Are there some that you have made that are worthy of consideration? Any that are on your list?
Received 3,226 Likes
Burt Gummer (11-03-2017)
I'd like lower, stiffer springs, but wouldn't be able to daily drive if it were any lower.
There are optional vents (hood, fender) that might improve appearance, depending on what you've got and what color the car is. For convertibles, you can change the covers on the hoops behind the seats.
Many like coverings to preserve the paint, e.g. Expel (X-Pel? Not sure of spelling).
Debadging, either partial or complete is also reasonably common. I removed the "JAGUAR" and "F-Type" lettering from the rear, but kept the "leaper" and the "S".
Recently there has been discussion of stripes.
I would think that the degree to which the F-Type appears to be on its’ tip-toes is in part related to wheel size, no? Wouldn’t you say that the tip-toe look is greater with 18” rims than it is with 20”?
I saw thie discussion regarding stripes. They have never been my thing. Can’t think of a car that I thought looked better with a stripe than without . Just a personal preference.
For stripes, I generally agree, but there are counter-examples. The Ford GT40 just doesn't look right without them. Again, personal preference.
For the record, is yours a coupe or a convertible? V6 or V8? Color?
Silver 2015 V6 S with 20" rims.
I would contend that the springs are a performance modification (chassis performance) unless done to improve the looks or styling to the detriment of handling. That falls into a whole other category.
I removed the leaper a couple of days ago (after having removed the JAGUAR and F-Type lettering months ago).
It has two holes and a small rectangular indentation underneath it, the two holes are for locating tabs in the leaper, I have no idea what the indentation is for (it sits between the two holes).
I spray painted the leaper in gloss black using caliper paint then stuck it back on using black silicone adhesive, about 3 mm lower than the OEM placement so it's now pretty much central instead of sitting "high". I cut the locating tabs off before painting it.
Looks pretty good I reckon and now matches the black S badge I stuck on a week ago.
Jagged Wire (11-04-2017)
You know that white lipstick on the grille surround on the Project 7? I thought of doing one in green - either spray plasti dip or wrap so I can take it off if I hate it. Something between British Racing and kelly green.
I would also like that big white dot on the door. Would I look like a poser?
Jagged Wire (11-06-2017)
Details here: https://www.jaguarforums.com/forum/f...inside-155712/
Misujerr (11-07-2017)
