O2 Sensor 2
My MIL light came on, so I checked using OBD and it reports P013E (O2 Rich to Lean - or something like that). It went off on its own; but I bought an OBDLink MX+. Sure enough the light came back on several days later - same code. But this time I can look at the actual values. It reports O2 Sensor 1 with a value of 0.00; O2 Sensor 2 with a value of 1.27. I have monitored the value each time I've driven. Values have been: 1.27, 0.74, and 0.81 (these are always after a trip, while the car is in park). OS Sensor 1 always reports 0.00. What's up with that?
o2-sensor-testing
My understanding is <0.3 volts is lean, >0.6 is rich. Optimal value is 0.45 volts.
https://axleaddict.com/auto-repair/B...-Do-About-Them
Other than the MIL light, I am not experiencing any other symptoms of bad ERG valve. I haven't had the car long - but I don't seem to be experiencing any performance issues. The car has only 7500 miles.
I'll be taking the car into the dealer. But I was hoping someone had some experience that could shed some light, and set my expectations.
o2-sensor-testing
https://www.jaguarforums.com/forum/x...ebacle-207249/
I've just seen code P0042, "HO2S Heater Control Circuit Bank 1 Sensor 3," and am working to get it in for repair. This follows close on the heels of P0030, bank 1 sensor 1, that was repaired last September. I'm hoping to work through the last of these bad O2 sensors before my CPO warranty expires...
Received 3,226 Likes
Judging by all the "my F-Type has crapped out" posts around here I must be the luckiest owner on the planet!
Two (count 'em, two) problems in 3.3 years of ownership on a five year old car with 56,000 km on the clock - the common rattly SC coupler / torsion isolator fixed/replaced under warranty, and a tiny split in one of the small expansion tank coolant tubes.
And that's with the larger crank pulley and tune for the last two years.
peppersam740 (01-08-2020)
It's been a couple of weeks since I got the car back from the dealer. I had two problems: O2 sensor, and occasional "low battery, please start engine". The car had been in the shop for a couple of weeks, driven very little. So it was started but didn't get much of a battery charge. I got it back and experienced the two issues. Dealer charged the battery and said THAT was the source of the O2 sensor issue. I was doubtful. But it's been a couple of weeks and neither issue has returned.
i believe it; it is like the tachometer generater on the XK engine of the 60's (ref. to my 1966 Mk 2) hidden at the back of the right-hand camshaft, accessible either by removing the engine or by having a triple-jointed friend (with very long, thin arms and the ability to see around corners) who also is an excellent mechanic willing to help anyone in need.
tallblondeguy
09-17-2009 06:02 AM
