OBD II
Old 06-28-2022, 03:05 PM
bluejaag's Avatar
Default OBD II
After having a flat battery 2x from the infamous OBD port II disconnect after the state inspections in years past, I asked the dealer today about when I took my 16R in for service as it's also due for the state inspection
He said they have an old bulletin which updates a module which should tackle the problem. I'm reticent about the software update because of the potential to dull the pops & crackles as I believe they're software controlled.
Are you familiar with this module update, if you've encountered this OBD disconnect issue on your car? If you've had it done, did it affect your exhaust sounds? I'm trying to judge if it's worth doing or not!
Old 06-28-2022, 03:15 PM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
I'd ask which module would be updated. I don't recall hearing about a solution to this issue.
Old 06-28-2022, 03:18 PM
Cheapo911's Avatar
Yea I think I've had the OBD disconnect issue before. Not sure how to solve it yet, does disconnecting the battery re set it?
Old 06-28-2022, 04:40 PM
kb58's Avatar
Yes, just remember to reprogram the windows, too.
Old 06-30-2022, 07:39 PM
BritCars's Avatar
Can you post the bulletin number / details? I also wasn't aware there was any cure for this. I get it after state inspection too. Quick disconnect once a year to fix it isn't a big deal
Old 07-01-2022, 08:37 AM
bluejaag's Avatar
Here it is - and it worked! Didn't have to use the manual key to unlock the car to find a flat battery, first time after 2 prior state inspections where that happened. it also didn't affect any sounds. Appears to be a permanent fix to this snarl - hope it helps,
Cheapo911 (07-01-2022)
Old 07-01-2022, 08:53 AM
Cheapo911's Avatar
So if I go to the dealer and say "Update the software for the instrument cluster and gateway module", what do I say to specifically NOT update so they dont do the update that mutes the exhaust?
Old 07-01-2022, 12:07 PM
Carbuff2's Avatar
I had to look up quiescent, LOL
Glad the issue was fixed...but keep an eye on the HAZARD triangle indicator just in case!
Old 07-02-2022, 10:46 AM
bluejaag's Avatar
@Cheapo911 Don't know for sure, my 2 cents would be to let them know you experience the battery drain issue after state/emissions inspection, and are they are able to fix it. It may depend on how many F types your mechanic sees - my service manager said his level 4 tech was very aware of this issue. Asked what the bulletin/service number was, and apparently JLR has removed the bulletin notice - I wonder why, as it seems to be one of, if not the most, prevalent of its quirks.
I may well be wrong about the pops/crackles being software related/driven.. I would confirm with your service manager that the only software update they do is just this gateway module and instrument cluster.
Old 07-02-2022, 11:50 AM
DJS's Avatar
DJS
DJS is offline
Pretty sure it’s an ECU update that affects exhaust noise. Used to be K309, don’t know if there were other later updates.
Old 07-02-2022, 01:05 PM
winstonsalemncxk's Avatar
Was this the Asheville Jaguar dealer? I'm in Winston-Salem and travel out that way fairly often. I might book mine for this service even though I have The Rock's quick disconnect solution installed.
Old 07-02-2022, 02:22 PM
bluejaag's Avatar
Great to know @DJS and @winstonsalemncxk Peter - it was, shout out to the tech Jason Lanciki, service advisor Brandon Sisk and service manager Jack Thill for what seems to be a fix for this
winstonsalemncxk (07-02-2022)
Old 07-06-2022, 06:56 AM
chasers03's Avatar
WCats
01-24-2022 02:37 PM
Frenchy
05-09-2017 06:21 PM
ek993
01-25-2017 10:08 AM
robertjag
09-24-2013 02:51 PM
police666
58
10-31-2012 02:41 AM
Quick Reply: OBD II
