OBD and State Inspection
Just wanted to add an observation after getting my local dealer to do my state inspection instead of the drive by shop. In Texas they plug into the obd port to run emissions check instead of tailpipe and we all know that can give the car insomnia and a dead battery a day later. Even had this after a routine service where SDD has been plugged into the car as part of the software scan.
Anyway today after the inspection finished I noticed that the service advisor removed a card from the dash with a reminder that after inspections on F Types the vehicle should be reset. Not sure if that was the procedure in SDD or they do what we all do and briefly disconnect the battery. But in any case, my car is now asleep in my garage, the warning triangle is out and I don’t expect the dreaded battery drain and jump start requirement in a couple of days.
Someone must have been reading our forum posts
DC
Sparky H (12-31-2021)
Oh yes...Most ODBII tools do not close the session properly (some do). I was referring to this statement "Even had this after a routine service where SDD has been plugged into the car as part of the software scan."
DC
DC
Anyway I found it interesting that my dealer was being proactive with laminated cards.
Therock88 (12-31-2021)
I remember raising the question about state inspection issues in the past, given that most are now done using an OBD connection. Strange (to me) was that there doesn't seem to be a pervasive battery drain problem after state inspections. The OBD issue seems to be driven by some tools vs others, and obviously whether the sessions are properly closed. So, something about the tools used by the states works well, or it's just that the testing procedure naturally causes the session to be properly terminated.
As I said, I found it interesting that the Jag dealership had a stack of laminated cards ready for the F-Type (it said specifically F-Type in for state inspection).
Had my car inspected in NYS by a non JRL shop. Had to disconnect the negative terminal later that week to get rid of the battery drain per instructions from this forum. The car is new (to me). Next time I will ask them to terminate the session instead of just unplugging the terminal.
DC
I'll second the comment that knowing the location is rather important to help.
On the general topic, I always got my inspections done at the dealer while the cars were under warranty, since wear items weren't due yet, and anything else they could do under warranty.
Since then, I always get my inspections done at Jiffy Lube. I wouldn't personally trust them to even change my oil, but they don't want any part of working on a Jag, so I've never had them fail, or even "recommend" anything. (They do really like the cars, though.) One of their locations isn't all that busy, and I avoid going when inspections are due at the end of the month. In and out in 10 minutes.
In California depending on which county your car is registered, vehicles have to pass a biannual smog check if they are newer than model year 1975 and older than 6 years. There are certain Zip Codes in certain counties that are exempt from testing. So are certain vehicles like motorcycles, older diesels, etc. Other states I have no idea although I have heard that some require safety inspections.
There all kinds of reasons they will fail you - for instance a check engine light will fail you no matter what the reason for the light is. Welcome to California.
peppersam740 (02-08-2024)
In Pennsylvania there is an annual safety inspection. They check tires, brakes, light bulbs, windshield wipers, etc. In the more populous counties there is also an emissions inspection. They check tailpipe emission for that. Those that drive less than 5,000 miles a year are exempt from the emissions inspection.
I think most of the CARB states require annual or bi-annual emissions testing and many of them require annual or bi-annual safety checks. CARB states are currently:
- California
- Connecticut
- Delaware
- Maine
- Maryland
- Massachusetts
- New Jersey
- New Mexico
- New York
- Oregon
- Pennsylvania
- Rhode Island
- Vermont
- Washington
Here in the Peoples Republik of Maryland, safety inspection is only required when changing ownership. And I don't think it even applies for cars with Historic plates. I got tags for my 31 Chevy by just going to a tag and title place and paying Maryland's exorbitant fees. That said, for an addl. $50 the state magnanimously gave me lifetime registration.
