OBDII port and battery drain
unhinged (and others); after searching, I was unable to find whether the issue with accessing the ODB port was tested/proven fixed. Reason for the ask: I'd like to connect to the ODP port for track days to get better driving metrics via RaceRender and hopefully find a remote tachometer application; as I am pretty short and the steering wheel is perfectly in the way of the tach. If Jag offered the tesla yoke steering wheel option, I would take it in a second....
apologies as I am new to posting in this forum. I think when i select quick reply it doesn't add my signature? [and found out that you cant delete posts :shrug:.
I'm hitting "reply" but in case my signature doesn't show again:
________________________________
2016 F Type R Convertible AWD V8
VAP crank/blower pulleys, ECU/Trans tune, lowering springs, down-pipe [with burbles tuned out]
Mtech brakes w/EBC pads
Black wrap w/ red stripe & accents, painted tow hook red [adds like 60hp]
Long time lurker; now more becoming active due to regularly autocross/tracking
You can test your device by checking if the light in the hazard switch stays on after about 10 minutes of shutting the car down - if it does, you have the drain.
I expect you have the same issue I do, and that it will never be fixed. Some have reported OBDC readers that do not cause problems, but both I've tried do.
As stated on another thread, I had a dead battery two years in a row after the Pennsylvania Emissions tester was plugged into the OBD port. Just a month or so ago, after the issue happened twice, I had the dealer keep the car for a few days to try to repeat the issue. The dealer did not plug in the emission tester, but used another device. The problem did not occur. I will be disconnecting the battery after state inspections from here on out. My car is a 2016 S.
John
John
#28
I too doubt it will ever be addressed. The only ones I think might have made enough of a stink about it to prompt action would have been those trying to get a better insurance rate by using an OBDC monitor. I saw a few mentions of difficulties with those but I think that people gave up rather than pursue it.
#30
#31
Since the dealer equipment does not cause the issue, I'm sticking with my professional opinion that this is a software defect, more colloquially known as a "bug." My black box testing indicates that the condition is unrecoverable without the battery module reset, aka, disconnection.
#32
Hallelujah, my Greenville SC Jaguar dealer, Josh/Rafael, after becoming acquainted with my 2016 F-Type R battery drain problem have fully cured the parasitic battery drain by installing 4 updates to the vehicles RFA, GWM, IPC & BCM modules. They could not tell for sure which one solved the battery drain problem but guessed it was the software update to the IPC, [instrument panel ?]. Jaguar does not publish to the dealers what their software update were designed to do unlike what our phone app suppliers do. They also don't pay the dealer for doing software updates under these circumstances.
If you have read my earlier pains and posts, I had a persistent, seemingly unstoppable 2.5 amp battery drain after shut down which was only initiated by plugging in and removing either my BlueDriver OBDII reader or my Allstate Milewise dongles. So Jaguar has a software update which will cure this OBD initiated parasitic battery drain problem on the F-Type.
Thank you ScubaAddict for keeping us focused on this issue and likely for getting Jaguar to address the problem.... and to many others like the TheRock who have helped with interim solutions like a quick and easy battery negative disconnect and AntiGravity Battery replacement. I don't regret installing these two enhancements along the way. AMEN"
#33
Thanks chasers03. I just bought mine and am suffering through this problem like many others. So far I have only eliminated several things. My car will be in the dealer's hands in a couple weeks, but until then I'm working to find the actual exact problem and hopefully the cause. Hopefully, I'll discover what's actually happening before they apply the shotgun repair. Once the problem is eliminated, one cannot perform a correct diagnosis.
#34
#37
Robert R Gilbert (05-15-2024)
Boomer from Boston
06-09-2024 05:06 PM
vdpnyc
03-02-2011 08:00 PM
