OBDII Port issue
Does anyone know if there was ever a fix for the OBD2 port issues with the battery draining if anything was plugged in? I read the posts about disconnecting the battery to reset and that fixed my problem but I never plugged my GPS tracker in again for fear of the same issue.
Jo
Jo
Darn it, ok. I will just have to troubleshoot it. Ill wait until the husband is back in town so he can deal with the battery reset thing. Thank you for your reply
Jo
Jo
There is work going on in the background to resolve this issue; I'm in contact with ScanTools (maker of many OBD diagnostic devices your side of the pond) and we are doing some work looking at the finer technical aspects of why this is happening.
Once I have run some more tests with Y-Leads and other adaptors, hopefully, fingers crossed we should be able to 'see' what is missing from so many devices that cause the F-Type to hang and subsequently drain the battery.
The Maryland Emissions Test causes the fault as well.
The NY test is done by an inspector and causes the battery drain to issue. I've never had it happen to any other make of car I've had, nor have I heard it happening to those around me.
I vaguely remember seeing similar comments, that the program has to have run to conclusion and THEN the device can be removed from the port without issue. Have never confirmed it independently though. But the only time I had the problem rear its ugly head was after the initial State inspection here in Texas...work done at the dealership never resulted in the problem arising.
