octain booster
Received 3,226 Likes
The F-Type fuel tank takes 70 litres = 18.5 US gallons.
Call it 18 gallons at a fill as the last .5 gallons is usually held in reserve.
So three gallons of E85 = 1/6 of the fill = approx 16% x .85 ethanol = 13.6% ethanol.
Call it 13% as most E85 is a bit less than 85% ethanol.
But JLR specify max ethanol content of 10% for the AJ133 and AJ126 (dunno about the four potter).
So probably no problems but it could be a bit iffy!
Then I'm in real trouble running straight e85 on my stg 4 tune😂.
Seriously though things only get iffy if you run more than e25 without being tuned for it, but the injectors have enough adjustment room (can trim +/- 20%) to keep things in good shape below that. What's really been great for me is I have a stg 3 tune that was just a little too hot for 93 octane so VAP had to send me a new file (which is perfect) and now I run the hot file with the ethanol mix. Doesn't ping anymore and runs like a scalded dog.
Not so sure about "no side effects".
I use boostane in quantities recommended by their app to boost from 91 pump gas to 93 octane. 93 from the pump is simply not available in Nevada and most places in the western US. I assume the boostane works. My Dyno results with VAP tune and lower pulley yielded 570 wheel, so it must not be pulling timing.
