Octane Boosters
Your OEM or aftermarket Tune is optimized to run on 91-93 Octane fuel. A radical tune could take Advantage of higher octane fuels, but then you would be stuck running that octane all the Time to prevent damage to the engine. Since the demise of tetraethyl lead, there is no commercially available octane enhancer that does anything more than a linear improvement in average octane. So yes, octane boosters (typically around 116 octane) can indeed increase octane, but you would need almost 1/2 gallon for every 10 gallon tank of gas to increase the octane by one point.
DPelletier (07-30-2018)
I must use one in conjunction with water/meth due to high boost. While testing on the dyno and carefully monitoring the knock sensors, I verified that the Lucas Oil Octane booster works as advertised. I also had a gasoline sample tested (17 gallons of fuel to one bottle) resulting in a final Sunoco 93 turned into 96 octane. I followed several threads on the overboosted Subaru WRX and Klotz had mixed reviews.
Just a note, as our engines are direct injection, I strongly encourage installing an oil catch can to intercept the PCV return. Unlike traditional fuel injected engines, NOTHING cleans your intake runners and valves. The water/meth injection in my case does but without it, any fuel treatment at best keeps the fuel lines and injectors clean. I just took apart the top end of my new V8R (Project Incubus) and the valves were filthy at 18K miles. For fun I cleaned them by soda blasting them and it took while....
Any opinion on additives for removing moisture from the fuel? The service departments (Jag and Maserati) at my dealer have both blamed some rough engine spells of both a 2013 XF and a 2015 Ghibli on the general poor fuel quality in this part of the country.
Thanks for that.
I determine the gas station I like to use by purchasing gas there for my VERY picky motorcycle. If it doesn't like it I never get gas there for my car. I usually go for Shell, or Exxon. BJ's gas, is amazing at making the bike and car run poorly.
fujicoupe (07-31-2018)
This is the first I've heard it mentioned in this F-Type forum.
I wonder, are we just looking for problems?
Let's see what unhinged has to say on this dark subject of carboned up valves.
Unhinged, what say you sir?
Well, I just realized that the cat is out of the hat already
https://noln.net/2018/04/01/dual-por...engine-design/
https://newsroom.toyota.co.jp/en/powertrain2018/engine/
Received 3,226 Likes
I think there are a handful running catch cans on their XJRs, XF SCs and XFRs.
Also, IIRC, there is an argument that a catch can is a waste of time on the AJ133 and AJ126 as those engines already have built in oil blow-by collection systems as part of the PCV system, per this quote from the AJ133 Technical Training PDF:
"The crankcase is ventilated through part-load and full load breathers and oil separators, which consist of a variable geometry oil separator, pressure control valves, and oil drain valve. This sophisticated system reduces oil pullover by over half."
Then again it says "by over half" so obviously there is still plenty of oil left behind and a catch can may make some sense.
Last but not least there is not a helluva lot of room to mount a catch can and apparently it's a tricky job, especially on the V8 which has even less room behind the block than the V6.
Chawumba (08-03-2018)
I run an oil catch can. I think I suggested it a few times on recent threads
I used this one (ditch the lousy hose) http://a.co/bWMjUBF
Lawrence
