Odd electrical outage on drive this morning.
I was cruising on the highway, and ALL the power went out - headlights, dash lights, audio, display. Just for a fraction of a second. Nothing "rebooted", the music (I was using CarPlay over UAD) pickedback up where it left off and the car really didn't miss a beat. Anyone else ever experience something like this? I see no way to diagnose such a quick flicker of power.
I was cruising on the highway, and ALL the power went out - headlights, dash lights, audio, display. Just for a fraction of a second. Nothing "rebooted", the music picked back up where it left off and the car really didn't miss a beat. Anyone else ever experience something like this? I see no way to diagnose such a quick flicker of power.
Toward the end of a 1.5 Hr, non-stop trip. Half tank of fuel. No issues since. Strange.
Not good. Happened again on the way home today. But this time it was longer (still under a second, though). The radio rebooted, the transmission gave me a flashing D and would not go in to gear until I stopped. The cluster knew it was running still, as the miles travelled would normally reset to 0 and they did not. Once stopped I could go to P and then to D and all was "well" again for the rest of the drive. But now I'm worried when it will happen next...
BONESTOCK (12-17-2022)
I wanted to close out this thread. After about 4 weeks of things getting worse and worse, I finally arrived to a dead battery at 3.5 volts and it would not take a charge. I got a new battery, and everything has been fine since. I suspect I was getting an internal disconnect in the battery causing my issues.
Thanks for reporting. Once again an experience that *might* indicate a serious issue has been traced to a very, very minor issue (minor in the sense that it is not an inherent issue with the car and it is easily solved). This can happen to a Bentley, Rolls, or any of supposedly faultless German makes too.
Did you fully charge the new battery before or at installation?
