odour in car after engine work
Hi. I had the VAP touring (quad) exhaust put on my car and the pulley and tune. Anyway when I first got the car back it had a very strong odour in the car, like an oily rubbery smell. I thought it might have been the old belt and pulley in the boot but I gave them a sniff (I'm known as "the bloodhound" at work) and I dont think it is that. I think it is probably just the workshop smell that has gotten into the car. It is gradually improving (I have cleaned the interior, been driving with windows down and leaving them open in the garage) but it is lingering. Any suggestions? I dont want to use a scent to mask it, because they always smell like a prostitute's panty drawer. I was thinking of a tray of bicarb or something like that.
Check your pipes. You may have a plastic bag stuck to them.
BruceTheQuail (09-23-2019)
Cheers. No oil on the floor, I'll look for the plastic bags. I think it has just kind of infused into the cabin. Sounding wicked by the way, it sounds and drives better in dynamic I think because it is holding the revs up a bit more (mine is auto). Not noticeably louder in dynamic, though.
Really, I actually prefer this engine note to the XKR, it is much deeper and less raspy.
Received 3,209 Likes
I guess you got the wrong pulley / wrong belt / shredded belt fixed?
If so what was the cause of the problem?
Gooday! Yes there is a new style of belt which they were waiting on, it has the ridges on each side whereas the one they put on had the fabric on the outside. Anyway it ended up being supercharger belt spaghetti. All running very nicely now, I've had it for a decent run along the M1 (a bit droney at 110kph but nice at 100kph), lovely around town and wicked under overpasses, I'm used to the extra power now so I barely notice it.
I know for sure that both the OEM and replacement tensioner pulley are smooth.
Per my previous post what you are saying doesn't make sense as I have run the single sided belt for some 18 months now with zero problems and so have plenty of others.
Or are you suggesting that the supplied SC crank pulley and belt somehow came with a replacement tensioner pulley that was grooved instead of smooth?
I'm sticking to my theory that the pulley was the wrong offset and/or the belt was the wrong length and as a result the belt was chewed up by the edge of the pulley.
On my car, all OEM pulleys for the SC belt were ribbed. Because limited double-sided belt sizes were originally available, I had to install a smooth idler and one-sided belt. Eventually, the proper size double sided belt became available and I was able to go back to the OEM ribbed idler.
I just went out to the car to check the belts and pulleys as best I could by just opening the bonnet/hood and shining a torch in, but I couldn't see let alone feel much at all.
So I pulled out the old OEM crank pulley, belt and tensioner pulley and lo and behold the tensioner pulley is ribbed (the replacement tensioner pulley is smooth) and the belt is double sided, ie ribbed on both sides!!!!
Except I think you are mixing up the idler pulleys (two of 'em) with the tensioner pulley.
Then again although I am/was 99% sure that the replacement pulley which came with my ETS kit was the tensioner pulley (I am sure it was described as this) it's possible it is one of the idler pulleys instead.
Maybe Stuart or Chris can set us straight on all this!
Anyway, attached is the page from the AJ133 Technical Training doc showing the various SC pulleys and the SC belt path, and although it still looks to me that the belt is ribbed on one side only and smooth on the other side that could be an illusion. Same with the two idler pulleys and the tensioner pulley, they look to be smooth but they could in fact be ribbed. Or else ribbed or smooth changed with the AJ126, the plot thickens!
It looks like they changed from a double sided belt to single sided from MY 2015 to MY 2016 or maybe 2016.5.
Also, looking closely at the diagram I posted earlier, there is only one pulley which runs against the "outside" of the belt (the smooth side on a double sided belt) and that is the lower of the two idler pulleys, the one just above and to the left of the crank pulley. So I'm guessing that this is the replacement "smooth" pulley I now have on the car and not the tensioner pulley.
Stuart and Chris, we need your help and advice!
Edit - I vaguely recall Stuart or Chris explaining some time ago that the later version of the larger crank pulley with the double sided belt no longer needed a new "tensioner" pulley, just leave the OEM one in place, which would make sense if we are talking about the lower of the two idler pulleys.
Of course I could be completely wrong about which pulley is correctly called a tensioner pulley and which is correctly called an idler pulley, it's just that I assumed the one with the "arm" hanging off it was the tensioner pulley and the other two were idler pulleys.
Also, I just checked out the Eurotoys site and it definitely says idler puller not tensioner pulley, and the VAP site doesn't mention either any more (ie no pulley change needed), so it seems my theory about needing to swap the lower idler pulley for a smooth one to work with the single sided belt may be correct.
Mine is silver and it weighs a helluva lot more than an empty coffee mug unless of course your coffee mug is ginormous and/or lead lined!
Edit - same OEM pulley and same OEM belt as mine so who knows when JLR changed to the black pulley and maybe a single sided belt.
As I keep saying, the plot thickens (yet again)!
BruceTheQuail (09-24-2019)
