Official Sticky Thread For Known Issues
#301
Anyone had their new f type delivered with paint issues/damage? Excuse me for not researching before posting.
But this really annoyed me, still is every time I look at my Polaris pain, chrome, even the glass. I'm not a detailing expert but I've washed the car and had it clay bared and polished but still I feel there is some type oxidation that happened to the car during transport.
#302
818 (03-25-2017)
#304
So even though your car was polished, it's possible a more aggressive paint repair step may be needed.
818 (03-25-2017)
#305
you're right jim, it's a lot more work than i expected.
just left a detailer's shop, he says it's oxidation for sure, the chrome and aluminum bits are all damaged by the oxidation. he invoiced me $300 bucks to get the paint fixed correctly.
we also figured out my production date is january 2016, this means my car was sitting on a lot (likely uncovered) for over 6 months.
SA this friday, lets see what the dealer will do about this.
My car had some very tough white crud around the hood intakes, mirrors, and on the flanks. I wouldn't call it oxidation, but it might be what you're talking about. Before getting Xpel applied to the car, this stuff had to be removed by the detailer, and it took a few fairly aggressive swirl remover applications. The detailer said he believed it was a known Jaguar problem with the adhesive on the plastic covers used for shipping. In any case it's ok now except for a small unreachable (by the polishing machine) section under the driver's side mirror.
#307
#308
#309
Polaris White...
FYI BRG was my first choice.. but not available anywhere.
Except a 2016 in San Jose specs just like your car. They didn't want to lease it to me.
#310
[QUOTE=818;1645882]damn, that's really weird, yea JAGUAR lets see what they tell me at the dealer.
I would suggest that you go directly to JLRNA with your issue, only if you feel that it is bad enough and dealership intervention isn't at the right level, nor the fix being too aggressive as a result of the "sitting on the lot" issue. Not to knock the dealer that I don't even know....but I think that this sounds like a "borderline" serious paint fix, and if so, an option of contacting JLRNA is something to ultimately consider. I just don't feel that you should have to deal with this type of issue on a new vehicle. I had this issue with Audi many years ago, and got rid of the car as a result from "backsplash" spotting. It was so annoying and hard on my eyes to see every time I got into the vehicle. Also, my first F-Type 2015 S, had two chips like a snake bite on the rear right quarter panel. The dealer tried to fix this (as the sales guy said it was fixable). The fix resulted in two paint dimples because their paint guy screwed up the simple fix royally. The dealer said.....we can have "the panel" repainted at the body shop, like it was a non -event. I stated "wait a minute", this will ruin the value of the car on sale if they run a paint meter on this and determine that it was repainted. Didn't hear you say this was as bad...but this came first to mind for me when I read your post.
You need to see how much paint needs to be buffed out to get this right, who is doing it, the outcome you should expect etc. etc. Then make your go/no go decision and contact to higher authority if the "no go" is the result, in a matter of fact professional way.
Good Luck, and I feel for you, but in the end JLRNA are the folks that should be contacted if an aggressive fix is warranted, which isn't what a new vehicle should have to have done!
#312
Thank you for your post.
I am deeply sorry to learn of your concerns.
Please kindly provide me with your vehicle and contact details via PM as I would be more than happy to forward this to the relevant market for further review.
Many thanks,
Amellia
#313
So something that's been bothering me a little, but I'm not sure if it's actually an issue, and not sure if it's similar to what others have experienced. I know there have been some issues with the sound systems, but mine isn't nearly as bad as some of the reports here, and it's on the 770 Watt system ('17 R, so it's the default option). Whether the car goes into auto-off mode at a light or whatever, when it turns back on there's a noticeable amount of alternator whine for a few seconds. It goes away quickly, and it's possible I only notice it because I've always been susceptible to high pitched sounds. So is that normal or something I should ask the service department about?
#314
#316
Excellent. That gives me something else to bother the service manager about. I just wanted to make sure that I didn't sound like an idiot going in with issues that aren't really issues. Might be related to a slight buzz I hear from the a-pillar speakers at volumes over 25 or so.
#317
#318
I started getting a "Charging System" fault about a week ago. Reset the battery and had the CTEK doing its thing all week. Finally took it in, suspecting an alternator problem. Turns out, a valve cover gasket was leaking and dripping oil onto the alternator. Both now replaced. Also, has a clicking noise from the driver's side wheel. The problem was that the balance weights on the wheel were stacked just a bit too thick and were just barely hitting the brake caliper.
#319
#320
Has anyone ever had the "Jaguar" decal/lettering start to fall off? I noticed that the "J" was crooked a few days ago. It seems like the letter is about to fall off. I was able to affix it with a small dab of silicone. Seems kind of cheap if the lettering can't hold up to 20 months of use....
