Official Sticky Thread For Known Issues
#381
#382
Received 3,225 Likes
I like it, as I still have a little bit of the "head bob" and "brake graunch" just as I come to a dead stop, and shifting into N just before I stop completely eliminates this, resulting in a perfectly smooth and quiet stop. I don't do it all the time, only when I know I will be stopped for a while.
I wish it worked the other direction as well, ie no need to press the button to shift from N to D, but obviously it must be the way it is for safety reasons.
That said, if you don't want this to happen why are you pushing the shifter forward anyway? Or are you talking about accidentally bumping it?
#383
I think that you should have to push the button to shift from Drive to Neutral, especially when the car is moving.
I like to shift using the sequential shifter in Sport, and sometimes I forget that I have shifted back to Drive, and instinctively push the shifter to downshift, ending up in Neutral.
#384
#385
My windshield wipers have a mind of their own. My wipers turn on, wipe the window once and turn off. This happens maybe about once out of every five times I turn my car on to go for a drive.
Anyone else have this issue?
Oh, and I'm NOT hitting the wiper lever by accident..
#386
drpaul (01-29-2018)
#388
drpaul (01-29-2018)
#390
drpaul (01-29-2018)
#392
Thanks for all the good ideas.
My windows are always spotless, so the sensor shouldn't be an issue and it only happens some of the time.
BUT, I do have it set in the auto mode!
So, I clicked it to the full OFF position.
I'm hopeful and think this will resolve my problem!!
Thanks again for all the input from you guys.
#393
2014 S BRG
3 issues i'v noticed:
1. the paint peeling on the rear panel behind the door (#3 on the list in the OP)
2. Park button on the gear selector is worn off, allowing the red light to show through the entire button not just the P and night.
3. Passenger side hood latch isn't latching/locking, possible cause of misaligned hood over a 1/2".
my warranty period is wrapping up i need to get it in. Any other bulletins i should bring up while at the dealership?
Other then that, an absolutely amazing driving experience.
Just an update: JLA took care of all issues and much more. Must say i am a happy with the F-Type once again.
![Icon Dance Cpatch](https://www.jaguarforums.com/forum/images/smilies/icon_dance-cpatch.gif)
dmchao (04-26-2018)
#394
I purchased my 2014 V8S December of 2017 with 26k miles on the odometer. The car was running great. However, as of yesterday the headlights began flickering and now my passenger side headlight is off and my driver side headlight turns on and off every few seconds. Also, the ECO mode has not been working. Car is always on even though the ECO light is on and is also indicated on the dash. The car now has just over 28k miles.
Has anyone had any issues similar to mine?
#395
#396
#397
As far as the ECO issue, the battery was rhe culprit. He said it wasnt holding the required charge for the system to work properly, therefore the battery is being replaced as well.
in a side note, i informed them of a slight ticking sound ehich appeared at around 250p rpm. I duplicated the sound with a tech in the passenger seat and he said "that doesnt sound normal, but to be honest I've never heard that before." It was a faint tick, but it was bothering me, so i figured I'd bring it up to them. 3 days later i get a call informing me that they would be replacing the supercharger as well as the water pump.... needlessto say, the car is still being worked on.
Thankfully everything is being covered under warranty...but im worried that once the warranty is up, these will be issues that will have to be fixed out of pocket...specially the supercharger fix...
ill keep everyone updated on the matter.
Dave
#398
#399
im en route to pick up the car now. Really hoping its all been sorted out.
As far as the ticking noise, it was easily detectable at 2500 rpm, with the soft top up, from either seat in the cabin.
Hope that helps.
Dave
#400
Hi folks,
Got a quick but important question regarding the safety features of the 2018 F-type 340 hp. Does this model comes equipped with the Automatic Emergency Break ? The manual seems to be very vague but I have seen references that claim it is a standard feature on the 2018 model. I couldn't find much about this one.
Any input is much appreciated.
