Oil Catch Can?
I am exploring the possibility of installing oil catch can. The primary reason for this is to address my concern that track use and spirited driving elsewhere will lead to sludge build up on the valvetrain due to blow-by.
Q1: Does anyone know if V6 prone to sludge and carbon under heavy use?
Q2: Anyone opened up valve cover after a year or so of use? What did you find there?
Q3: Anyone installed oil catch can, and if so how much do you 'catch' between oil changes?
Thanks!
Thanks!
Thanks!
Thanks!
> phoned the service advisor for the appointment to change oil/filter and asked about the 'oil catch can' and he gave me the usual lecture on the fact that they would not modify the car in any way etc. etc.. And if the car needed this modification then Jaguar engineers would have added it already.
> The master mechanic that works on my car will be able to give me some feedback around any incidents he is aware of concerning fouled valves / and has he installed one before etc.. and I will pass it on. He most certainly would add the oil catch can if I asked him to if it was my preference to do so and he believed no harm would come to the engine.... and in this case it seems obvious no harm would be done.
Lawrence.
F Type Terry (05-13-2016)
http://www.e90post.com/forums/showthread.php?t=893748
http://f30.bimmerpost.com/forums/sho....php?t=1025545
http://blog.modbargains.com/get-nuts...et-clean-tune/
Unhingd (05-13-2016)
As mentioned, my F type R was in for oil / filter today and here are a couple of points that the master mechanic made based on questions I asked him:
.. Is an Oil Catch Can a worthwhile investment on the V-8.. He advised that the Jaguar needs to be pushed hard, at least at times otherwise you end up with rough idle / carbon build up etc .. and he sees this all the time with cars that are babied. His view of my Jaguars (over a few years) is that they are kept quite clean due to my heavy foot. However, he knows of cars with Oil Catch Cans and although they usually only collect a spoon full of oil over the change interval, his opinion is that its better caught than ending up on the valves. I'm going to order one and he said he would install.
.. His other concern is that too many owners wait and exceed the oil change recommendations and he says this will lead to problems over time.
.. The famous speaker rattle is an upcoming 'fix' from Jaguar that he expects to see in a month or so.
.. I had the 02 flash and my car still snaps and pops.. not sure but it may be a bit less now, however will judge this in over a week or so.
.. And as an aside, the finance rates and information for the new XE is going to be released tomorrow.
Lawrence.
Lawrence.
We discussed about putting a catch can on a 5.0L XFR here https://www.jaguarforums.com/forum/x...an-yet-138452/
I actually have a catch can sitting under my desk to put on the XJR but haven't got round to it.
There are a few members with older Jags, 4.2L who have put catch cans on, I think they are also linked back in that thread.
The biggest concern I have heard from people who know, is that fitting the catch can could create a source of a vacuum leak. So ideally we should have a made-to-order hose setup that just clips in place.
There are such kits for the Mustang V8, but there is also the demand for them which justifies making OEM-style hose kits to suit. With the Jags it's such a small volume I think it will be a struggle to make a truly OEM-style setup.
![](https://ep.yimg.com/ay/yhst-37354654005614/2015-mustang-gt-plug-n-play-oil-catch-can-separator-19.png)
Lawrence.
Lawrence.
Once I get around to doing it, I'll take a picture. As well, I'm not sure which brand I will end up with.
As well, he did not say it was a strong recommendation, just a preference.
Lawrence.
JigJag
05-18-2016 08:22 PM
JimC64
05-09-2016 07:27 PM
