oil change
Appreciating that the "normal" way to drain the engine oil on an F-Type is thru suction (suction hose right beside the filler cap), does anyone know if the F-Type also has a traditional drain plug underneath? As I have not yet had a chance to put my F-Type up on a hoist to look. Have checked this site and have also Googled, but do not seem to find the answer to my question.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
For the V6, all available info points to WSS-M2C925 or STJLR.51.5122 specs. The only oil I can find meeting those specs is the Castrol Edge Professional OE 0-20W that appears only to be available in Europe. My local dealer uses Castrol Edge Professional 0-20W (no OE) which neither claims nor denies meeting those specs. It could be that the OE stands for "original equipment", is the exact same oil, and was established for market differentiation (confusion) to allow dealers to sell something at a higher price (which they are doing with the non-OE at $13.35/liter anyway). Anybody have any comment or confirmation of suitability or similar application by other dealers?
Received 2,263 Likes
Anyway, went to the dealer to get an answer.
The Castrol edge professional 0w-20 (no trailing letters) specifically meets the Jag specs as stated on the bottle.
Wow . . . poor guy just wants to know whether there's drain plug or not, and he gets a dissertation on oil specs.
I believe the answer is that there is no drain plug on the oil pan. However, you can buy an oil extraction (suction) device very cheaply at almost any auto supply store or on-line.
Mikey (10-12-2015)
Maybe I should have been more clear on my response, I to am interested if there's a drain plug or not. I'm not for sure in my mechanic is equip to vacuum out the oil but if our cars have a drain plug and I could obtain the right oil then I know my mechanic could change the oil. Defiantly not trying to hijack the thread so my apologies if it came across that way.
There is NO DRAIN PLUG
inmanlanier (11-29-2022)
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
If it's a V8 lump, then it sure does....
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/343x233/screen_shot_2015_10_12_at_21_36_46_c8b269a363642b5f1806fe6c0a218c46bec6fd80.png)
Tel,
Thanks for the clarification, but I suspect you'd have remove the large panel covering the bottom of the engine. Thus, it's not conveniently accessible without putting the car on a lift, then removing that panel.
With an easily accessible extractor tube, the preferred method is a no-brainer, while leaving the car on the ground.
THIS IS INCORRECT. The V6 very much has a drain plug. Its in the same location as the illustration above. JLR also outlines oil change procedures using the siphon/vacuum method or drain method. If you do go with the drain method, it calls for a NEW drain plug and torque for the drain plug is 24nm.
That may be true, but you need to know exactly which formulation of the many that they each sell. Note on the bottles: different grades meet different specs. And until Jag refers to standard lubrication industry specs (eg API or ASTM), it is difficult to know which meets the specs Jag specs. For example, the Jag specs appear to require extremely high levels of Titanium in the oil additive package.
Tel,
That is correct; the splash guard underneath has to come off first to gain access to he sump plug.
Sometime down the line (after the warranty expires) I will remove mine, measure up, and cut a 2 ½'' hole out that I can fill with a nitrile bung, to gain access without dropping the guard in future.
Having never used a suction pump, I'm not sure that it can remove the last of the oil sufficiently thus taking away the most contaminated or 'heavy' oil in the bottom of the sump?
"The cure for pollution is dilution."
