Oil change suction devices
I know there are various devices to suction out the oil from the top rather than from the bottom. Anyone who has one and has experience using it I’d like to hear your impressions. Currently I am still under warranty for maintenance, but I want more than once a year oil changes.
Thanks folks!
Thanks folks!
Received 2,626 Likes
I also have a Mityvac, Model # 7201. It's the one with the manual pump handle as I don't have compressed air available in my garage. I just looked on Amazon and the price has gone up considerably. I paid just under $100 for mine a little over a year ago. I see Amazon has some "knock off" extractor pumps for a little less money. Just be sure you get one with enough capacity to hold all the oil from the sump which will be just under 7 quarts. It's actually a pleasure to change the oil & filter on the Jaguar, it's a very surgical procedure and easy to do. Especially for someone who spent the last 50 years crawling underneath my vehicles to do it the old fashioned way.
And of course you need the correct size wrench to remove the cap on the filter housing. And I highly recommend a good quality torque wrench, and one designed for low level torque readings and not one made to torque lug nuts with a 2 foot handle that goes up to 150 ft/lbs. The housing cap requires 25 Nm or 18.44 ft lbs. and you will get you best accuracy with a wrench that goes up to 50 ft lbs or so. There are torque wrenches designed for bicycle use that read lower values. They are also useful for things like spark plugs and drain plugs on vehicles that have a conventional plug on the oil pan.. I have a cheap one and it was hard to use and read so I finally bit the bullet and bought this one:
I like it because it can easily be switched to read different measurements like Nm, ft/lbs or inch/lbs and comes with a certificate of calibration. It isn't inexpensive but good tools seldom are.
Steelman 06128 from Amazon is what I got.
Discussion here:
https://www.jaguarforums.com/forum/f...source-209637/
Discussion here:
