Oil filter Wrench Source
https://asttool.com/detail_page.php?...nge%20Products
However, unlike my direct orders to Assenmacher in the past, I had to order the oil filter cap from ToolSource.com (Assenmacher directed me to them). The cap shown in the below ToolSource.com link is the oil filter cap made by Assenmacher.
https://www.toolsource.com/oil-filte...b216eln6o1vq43
BTW, I tried the plastic oil filter caps too (don't ask how many I have collecting dust). Think I've finally learned my lesson. Steel is the only way to go if we're talking about oil filter caps.
RGPV6S (10-21-2018)
Received 3,225 Likes
I bought one similar to this a few years ago, cheap as chips from my local auto parts store and works a charm: https://www.ebay.com/itm/STEELMAN-06...wAAOSwnN9btxu4
The beauty of it is it is a universal fit and I have used it on several cars, and it has loosened off a couple of really stuck hard filters.
But don't get the one in the linked ad, you need one that looks damn near identical but the inner edge of the strap (where it grips the filter) is covered in a 1/4" thick strip of rubber. I couldn't find one exactly like that on Fleabay but auto parts stores should have them.
I ended up using one of these I found in the back of a drawer in my tool chest. Just put sections of thick latex lab tubing on each jaw to prevent scratching.
https://www.homedepot.com/p/Husky-Un...3JFW/204762449
BTW what ever you do do not buy one of the oil filter sockets made of plastic they will be useless - even if it is the correct size. Initially that was all I could find locally and both I tried I had to return.
Queen and Country (03-11-2019)
Although the other one did work fine with once I put the rubber tubing on it.
As an update, I used tin foil to make up the space and was able to remove the cap. I believe the correct size for mine is a 89mm. Will order one for next time!
Using a caliper gauge, the flutes on the filter housing measures 87.5mm. My wrench measures 88mm. The proper wrench is an 88mm x 15 (flutes). A google search will net lots of results.
EDIT: Thinking further about this, since the wrench and filter housing have an uneven number of flutes, I am uncertain exactly how to measure them. The right wrench might also be an 89mm x 15.
I bought this one from Amazon...............it states it is specifically for Jaguar, although it is classed as a 90mm x15.
It works on my V6.............
Motivx Tools 90mm 15 Flute Oil... https://www.amazon.com/dp/B01BS6M04I?ref=ppx_pop_mob_ap_share
RGPV6S (10-15-2019)
RGPV6S (10-15-2019)
I did some research. Turns out I have the 90mm wrench which fits loosely but will round off the plastic flats on the filter housing if there is significant resistance. Knowing my luck, the right wrench may be an 89mm x15 rather than 88mm x 15. My apologies if that’s the case.
Can't find an 89mm version so I think we are down to either the 88mm or 90mm which looks to be too big.
Just ordered Steelman 6138. 15 flute by 88mm. About $10 on EBay. They are listed for a Hyundai.
Just got my 90mm version Steelman 6128. Fits with some slop so I could see it doing damage to the plastic oil filter housing.
I did like the tin foil solution! Good thinking.
