Oil Level Gauge Reset
My Oil Level Gauge appears to be inaccurate. It reads Overfilled, but when the Shop Foreman attaches an OBD reader, he gets a 97% full reading. Is there a way to reset the gauge so it reads more accurately? We are taking the readings waiting 10 minutes, level service. Also, did a search and found nothing useful on this topic. Thanks.
Perhaps you simply need to update the average oil level reading?
Turn the Ignition on.
Press and hold the Cruise Control Cancel button for more than 5 seconds
Turn the ignition off.
Turn the ignition on.
Scroll through the Trip Menu to view the oil level display, to verify that the oil level value has now been updated.
Sparky H (08-12-2021)
CarBuff2, I tried your reset protocol and I still get an "Overfilled" reading. Thanks for the advice. My concern is that the gauge is not reading at all. Stuck on "overfilled." If I believed it was simply off by 3%, no issue. Trying to avoid unintended consequences. I don't want to ask for a complicated repair/replace from the dealer
that I regret later.
And don't they have another F-Type to read for reference?
You can also switch it to a ‘live’ reading, which is useful when topping up (which I’ve never had to do except when changing the oil.) The procedure is in here...
https://www.dropbox.com/s/ncfhyazedn...ng%29.pdf?dl=0
The following 3 users liked this post by DJS:
I tried it and it worked. Parked it on a slope, waited 10 minutes and it read 2 ticks above the mid point. Now, I know it works so I am much more comfortable with accepting the inaccuracy and moving on. Thanks for the great idea.
ferrral (08-11-2021)
Thanks for the info.
Pooling the oil diagonally to get a lower reading only shows that the sensor is accurate and you are overfilled. Best to pump a some out to get into the ok range on level ground. Driving with an overfill is not a good idea.
Agree that driving with the Oil "overfilled" would be a bad idea. Fortunately, I'm not. When I started this thread I had already determined that the gauge was inaccurate, my concern was to get comfortable that the inaccuracy (by percent) was reasonably stable. To recap, when it initially read "overfilled" I immediately went to the dealer. The Shop Foreman and the Service Director checked the oil using a device attached to the OBD port and when my gauge read "overfilled", it was in fact 97% full by their more accurate reading. Since my gauge has not moved in a month I was getting concerned that my gauge was not working at all (not just being a few percent off.). The slope trial proved the gauge works and that the compromised reading was still over half full. From this I have deduced that my gauge is between 3 and 15% off. The 15% is a guess based on my incline reading. Am I missing something? Thanks again to all for input.
scm (04-14-2020)
![Icon Mrgreen](https://www.jaguarforums.com/forum/images/smilies/icon_mrgreen.gif)
I feel the same as you, I don't always trust new-fangled things like electric fuel gauges and electronic oil displays.
![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
The first thing I did after changing our oil myself 'by the book' was to compare the readings COLD, and AFTER TEN MINUTES (the 'instant' reading in both cases).
On the display, how low is the oil when it is reading in the middle (where the oil can icon is located)? Is it 1/2 quart low in the middle?
![Icon Saywhat](https://www.jaguarforums.com/forum/images/smilies/icon_saywhat.gif)
SS4PK (04-14-2020)
What were your results from the dealer? I'm in the same boat. I just refilled with no more than 7.1 liters (not 7.25) and while using live to monitor the last fill I got to overfilled. I've run the vehicle for 10 minutes to displace as much oil as possible and let it set 10 before taking a reading per the instructions but I still show as overfilled.
