Oil level puzzle
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have a MY2018 V6S 380 AWD Coupe. The last service was 8 months ago in September 2020. I regularly check the oil level using the Vehicle Info panel on the dash and have not needed to top up the oil so far. The reading hasn't moved as has always been 'OK.'
This morning it read 'Oil Overfill.' which has me puzzled. I haven't added any oil since the service last September, and I would have thought that, with normal wear & tear, a little oil would be lost and burnt off. If the sensor was just on the limit, why hasn't it shown 'Oil Overfill' before?
I removed about 30ml with the MightyVac and it now reads 'OK.' Anyone experienced this before? Is my oil level sensor to be trusted?
My last ride was a Mercedes AMG, which had a dipstick consisting of a thick flexible wire and a plastic slug at the measurement end. It followed a fairly tortuous route, so the decision by Jaguar to use an oil level sensor probably isn't based on access.
Has anyone experimented with a dipstick mod on the F-Type? Is this even possible?
Received 3,226 Likes
Lots of posts and a few threads here and there across several sub-forums about "the leccy oil level read out sucks, why didn't JLR just give us an old fashioned dipstick, is there a way to fit a dipstick to the AJ133 or AJ126, can the oil extraction tube be used as a dipstick hole" etc etc, and the answer is NO, NO, NO and NO.
We are stuck with the leccy read out and there is no way around it.
It's also temperature dependent. If you filled it when cold, then check the level while hot, it's likely to show overfilled. I follow the Jag oil change procedure, filling and checking the level while the engine is warm. If I check the level after the car is sitting overnight (cold), it's often shows less than if I check it 10 minutes after turning off the engine (warm).
As others have pointed out, the oil level reading is extremely sensitive to being perfectly level. Even a garage with a normal pitch for rain runoff can throw it off if you're right at the full mark. I'm not sure what the trigger point is for overfill but if you're right at that volume then you could dance back and forth over the line. I've had mine do the same thing on occasion (reads full 95% of the time, overfill 5% of the time without adding/draining oil). As long as the majority of the reads show full you should be fine.
