Oil temp and pressure via OBD port.
Hi,
I wonder if anyone has managed to 'tap' into any oil data via the OBD port on the F yet?
I miss the temp and pressure readings for oil, and wondered if it can be read by possibly one of the many OBD II readers on eBay with an iPhone?
Can anyone tell me where the OBD port lurks?
TIA
TIA
Hi Tel ,
engine doesn't have an oil pressure sensor , so getting any information via OBD will be difficult . Oil temperatur is measured by the oil-level sensor in
the oilpan and is transmitted to the ECU . Oil temperatur and level are send together in a serial protocol . Oil level obvisiously is decode but no idea whether temperature is decoded too
and passed to the bus system .
So there is still hope to get some data.
Regards
Ulrich
Regards
Ulrich
The following 2 users liked this post by WayneB:
buickfunnycar.com (07-16-2015),
Tel (07-16-2015)
There is no oil pressure sender. When I was looking into this I learned there is a plug on the cylinder head that can be removed and a sender installed. Also on the rear of the block. Neither is used by the factory.
Hopefully someone comes up with an aftermarket gauge solution, preferably that displays on the existing screens.
If a value isn't in the OBD standard, a generic reader won't show it. The standard values are here:
https://en.wikipedia.org/wiki/OBD-II_PIDs#Standard_PIDs
Even if there were a sensor (as noted above, there isn't) it would fall into the "non-standard" or vehicle-specific" category. My knowledge is a bit stale, but I worked on the RomRaider project for a while. It's heavily oriented towards Subaru, both by demand and the fact that the Subaru protocol and ECU images are understood. Between a documented non-standard protocol and much reverse engineering, it's quite capable.
I don't expect anything of that level for JLR, but would enjoy a pleasant surprise. Not holding my breath though.
Well, given that the oil pressure warning light coming on while driving is generally an indication that it's Game Over for the engine in most marques, I'm unsure as to what you want to measure? An Alfa Romeo I used to own had a separate oil pressure gauge, which I can remember watching the reading drop as the oil temperature rose one very hot day while stopped at traffic lights. Sometimes, ignorance is bliss...
Well, in my offshore style speedboat, the oil pressure drops after I go ***** out for too long. This tells me to slow down to cool the oil a bit before I throw a rod. If I let engine speed drop to an idle without first cooling the oil down a bit I can hear lifter noise and feel vibrations that are not otherwise present. I believe the gauge is worthwhile for that reason. It's not as important for a gently used car but some of us don't use our cars gently.
Similar info might help more performance oriented folks avoid damaging the much more expensive engine in ther jaguar. Not everyone will know what the information means and many might ignore it. That doesn't mean it should not be available to those of us who want it.
When I look into an E-Type, I like what I see on the dash with regards to monitoring the engine condition. To an engineer type like meself, it's almost a necessity.
I'm just surprised a simple oil pressure and oil temp gauge isn't in the cluster, or even available via the OBD standard string?
The manufacturer simply says not to run WOT for more than 5 minutes at a time and the data is logged in the ECU for warranty purposes. I can get away with running it hard a bit longer in cold seawater temps before the oil starts to lose its ability to maintain full oil pressure, but only race boats and some outboards can sustain full throttle indefinitely. There are aftermarket oil coolers that address the issue but I have not bothered yet. It's already thousands of dollars per year to run the boat without upgrades. Despite the maintenance I can expect a full rebuild at 1000 hours of use. That is if I don't break it by running it hard with overheated oil and reduced oil pressure. Fortunately there is a gauge to watch.
i was using the behavior of the oil pressure gauge in my boat to illustrate the utility of an oil pressure gauge in high performance applications in general, and specifically as it pertains to preventing engine damage from overcooked oil. It was in response to a post questioning the utility of an oil pressure gauge at all.
aholbro1
08-05-2021 05:02 AM
