Opinions on battery
Assuming you keep/kept the battery on a maintainer/trickle charger and/or drive it on a regular basis... I would not change it yet. You will usually get a sign that it is weak before it just outright dies (this is where someone will come along and post that THEY had a battery that just died with no warning....Thus I said USUALLY). I would think you likely have a couple years left.
It is a personal preference though...If it worries you that it MAY die at some point, certainly change it out any time. It is not a huge expense.
DC
DC
I changed out the battery on my 2015 at almost 7 years with no sign of any problems. I have read that the glass mat batteries (AGMs) last a little longer than the flooded batteries. Cost wise, I suggest searching the aftermarket for a replacement . My local Jag dealer wanted $400 for a battery and they are available elsewhere for less than half of that.
Just replaced the battery on my '15 today, actually. H8 AGM @ Costco - $179. It was not showing any electronic hiccups yet, but it seemed to crank just a little slower, and the resting voltage was under 12.4 kept on a maintainer, so 'twas on the way out.... Why ever did Jaguar make the ground cable so short?? Surely another couple inches wouldn't hurt.
Kind of a loaded question - no telling when one could fail. I would think a 2019 would be good for at least another year and maybe two assuming it’s not showing any signs of weakening. I replaced my 2016 battery last year - no issues at all and the car only has 17k (3000 in the last 3 years). It’s stored in a climate controlled garage and I have a CTEK but haven’t used it yet. I replaced to avoid having a random issue and to avoid trying to find a way to get inside if it went dead.
Use the fob's emergency key to unlock the driver's door., pop the hood and connect a booster to the underhood terminals (have your fob handy to turn off the alarm!) and you can then pop the trunk and sort the battery out.
OzXFR (03-24-2022)
Received 3,209 Likes
Mbourne (03-28-2022)
If you often move the car around for short periods, you will reduce the battery reserve quite a bit.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
So, that is why we make it a point to drive our F for 30 - 45 minutes, all at one time, on a weekly basis. (as, in the winter).
I HAVE a maintainer, but haven't needed to use it AT ALL following this regimen.
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
Aside from being cautious when the temps are too cold for the summer tires, it's FUN!
car5car
10-13-2018 09:15 AM
