Overfilled Oil
Overfilled Oil
Ok, I have read several threads about this but had a question. Just how sensitive is the oil gauge in the F-Type? I had the oil changed a few months back, have driven it a few times since then and last week checked and it said overfilled. I pumped some oil out of it and still get the overfilled reading. So i took a long level and my garage floor is about half a bubble off (front end higher). Could it really be something that slight affecting the reading?
Or, even more conveniently, you simply take the reading before starting the engine the next day...
Phantomf4collector (06-30-2020)
This slight slope doesn't seem to affect our oil level readings in the garage, but I can tell a difference when the car is parked on the approach to the garage (where the nose is ~ 2 inches higher).
peppersam740 (07-01-2020)
Received 3,209 Likes
Add me to the Overfilled Club. My '18 Base V6 kept showing overfilled no matter how I checked it (+10 minutes from shutdown or cold read first thing in the morning). It's a RWD and done at a busy dealership so I figured it couldn't be over by much. Sucked out about 300ml with the MityVac and now it reads full. They also overfilled the coolant reservoir by about the same amount (filled all the way up to the neck), so I sucked out the excess with a hand pump. Neither would have affected internal systems but I feel better knowing they are within spec now.
