P 7 Bumper-less Grille Installed
Old 06-23-2017, 11:05 AM
myer's Avatar
Absolutely superb!
  #282
Old 06-23-2017, 01:35 PM
NigelW's Avatar
That really does look very good.
I am looking forward to doing this to mine someday.
Mpowerr (12-15-2019)
  #283
Old 06-23-2017, 02:43 PM
FR500GT's Avatar
That came out great!
  #284
Old 06-25-2017, 03:31 AM
Meister_Kajo's Avatar
So people,
It is now completed and in the appendix the result with a few pictures more.
Here is a short assembly feedback:
The conversion was somewhat tricky, but the Jaguar dealer has done everything to my satisfaction.
Manual:
Dismantling the previous front bumper
Expansion of the previous grill
Clipping of the parking sensor adapter into the honeycombs (5th honeycomb from the center)
Mounting the Straight Park Sensors (The straight sensors are invisible from the front)
Removing the Styropor behind the old grill
Paint the crossbar and the cooler behind the old grill in matt black
Disconnect the cables from the old parking sensors
Extend the cables of the parking sensors
Lay the cables of the parking sensors towards the grill edge on the back of the honeycombs with 2K glue
Installation of the new grill and installation of the front bumper
Adjustment and alignment of the new parking sensors
Attach my own Stoh n sho license plate
Costs:
P7 Grill and Surround approx 320 €
Painting the surround 60 €
2 3D adapter 40 €
2 Straight parking sensors 26 €
Cable 2 €
Paint Blackmatt 5 €
Installation and set-up of park sensors 470 €
License plate: free of a friend
Total: 923 €
For a front grille quite a bit, but I find the result very great!
A good news still for those interested in the 3D adapter. These are now ready and I have this with me. More about pm.
Following some pictures:
The following 5 users liked this post by Meister_Kajo:
domino_z (06-25-2017), Itismejoshy (01-04-2018), JgaXkr (06-25-2017), Mbourne (07-08-2017), myer (06-25-2017)
  #285
Old 06-25-2017, 04:47 AM
myer's Avatar
Fabulous job, you should be very pleased a really professional job!
The registration plate looks really good, definitely the best position.
I have just sent you a PM with confirmation
  #286
Old 06-25-2017, 05:37 PM
jleuz1's Avatar
Great job. Looks great.
  #287
Old 06-25-2017, 09:48 PM
domino_z's Avatar
10/10 for effort
but i can't get past that crash bar
  #288
Old 06-25-2017, 11:43 PM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
Originally Posted by domino_z
10/10 for effort
Agreed, there must be a simple and relatively cheap way to hide that bar a bit better. Maybe it could be wrapped in gloss black, or as a ghetto fix maybe even apply two long strips of black duct tape, or better still one strip of extra wide tape if such a thing exists.
Edit - plenty of 6" wide or even wider black duct tape out there on eBay, but I reckon 6" wide would do the trick nicely. Maybe wrap it around the back of the bar and superglue it down across the back?
  #289
Old 06-26-2017, 12:32 AM
BruceTheQuail's Avatar
Received 1,291 Likes on 889 Posts
Looks awesome. I think maybe the crash bar is more noticeable in the pictures because you are looking straight at it. From an angle it wouldnt be so prominent due to the depth of the grille. The only way to really hide it would be to have deeper mesh on the grille then you'd only see it looking dead on, from like 2 feet off the ground.
I'd have it as is on my car in a flash, but I'm not very handy.
  #290
Old 06-26-2017, 01:11 AM
IronMike's Avatar
You are correct, the bumper bar is not as noticeable, actually hardly noticeable, unless standing almost directly in front, in bright daylight, at less than 10 paces. Stand back 20 ft. or more, or more than 30 degrees to either side, and the bar is far less obvious than the above pictures might lead you to believe.
People need to keep in mind that this look, with the bumper bar entirely behind the grille, is a hundred times cleaner than the protruding OEM bumper bar that previously bisected the grille opening.
For those really bothered by the appearance of back bumper bar, another way to obscure this further would be to add a finer mesh screen, also painted matte black, behind the P7 grille. This technique is more common than you might think...
  #291
Old 06-26-2017, 02:16 AM
IronMike is right. You can see the rear crossbar only when the sun is directly on the grill and if you stand directly at the same height.If you are two to three meters away you can hardly see it. Or if it is not sunny ...Perhaps make other users the crossbar invisible when they start their own project ...
  #292
Old 06-26-2017, 08:03 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
If it's good enough for the P7, it's good enough for me. The crash bar is also flat black on the P7.
  #293
Old 06-26-2017, 08:28 AM
RickyJay52's Avatar
Received 1,601 Likes on 861 Posts
Isn't that the point?
(I also agree on the other point, 10/10!)
  #294
Old 06-26-2017, 08:29 AM
RickyJay52's Avatar
Now that's what I call a bevy of beauties!
  #295
Old 06-26-2017, 10:46 AM
myer's Avatar
My thoughts exactly, the P7 has the "visible bar", so that is how it should be!
  #296
Old 06-26-2017, 02:04 PM
IronMike's Avatar
I would also suspect that painting the bumper bar with a black zolatone type textured paint first, then follow that with solid matte black... that the granular texture of the finish would make the bar even loss noticeable, because of the way the textured surface refracts light.
  #297
Old 06-26-2017, 07:44 PM
jleuz1's Avatar
I noticed the crash bar and the sensor mounts when I first installed my grille, but probably because I was looking for them. Now I seldom notice them at all.
  #298
Old 07-08-2017, 11:19 AM
Unhingd's Avatar
Default Perfect sensor solution
Meister_Kajo definitely has the perfect solution for the sensor mounts. The sensor, with its rubber grommet, is a squeeze fit into the adaptor, and the adaptor is a snap fit into the grille. Just for safety I will use just a drop (to allow later disassembly) of silicon to secure the respective parts.
The following 2 users liked this post by Unhingd:
Itismejoshy (01-04-2018), JgaXkr (07-08-2017)
  #299
Old 07-09-2017, 02:05 AM
looks good. Now connect to the mounting and connecting of the sensors. have fun
Unhingd (07-09-2017)
  #300
Old 07-10-2017, 12:00 AM
IronMike's Avatar
Has anybody determined which style of sensor is best for connecting and running the wires?
Also, is anybody else having to sand the Interior Diameter of the adapter to get the sensor with rubber grommet to fit.
Also noting that the sensor does not fit flush to the front of the adapter before the flange on the backside bottoms out on the back of the adapter. Apparently need to sand or shave about 2mm off the thickness of the adapter to get a flush fit. I have tools to accomplish this... just wondering if I'm the only one having to make these manipulations.
Quick Reply: P 7 Bumper-less Grille Installed
