Kenneth, send a PM to Meister_Kajo. If he still has access to the printer, he'll set you up.
I think someone else on the forum is also making them, but I can't remember who.
Hi,
Thank you for your generous help.
I am wondering where to buy these P7 grill plus surround ? I have found a supplier in UK but it will cost me 430 English pounds to have them and that does not include delivery charges?
Do you know any suppliers that can order for much cheaper price?
Lastly, as for the sensor which should I order, the front sensor or back sensor ? Or their different and although it was recommended to fix the rear sensor to the P7 grill because it can hide the cables nicely ? Pls advise
regards
That price is about the going rate. But try these guys: Land Rover Parts and Jaguar Spares | Britcar UK Ltd You'll need both the grille and the surround. You can buy aftermarket for the same or less, but the OEM quality is far superior.
I originally thought the rear sensors would fit better, but the front sensors actually fit best into the 3D brackets, so you can just reuse the sensors already on the car.
How is everyone mounting their stock sensors flush with Meister_Kajo's adapters? Even after removing the rubber grommet altogether, I'm ending up with quite a recessed sensor (and subsequent false alarms)
I pushed my sensors a bit further into Kajo's mounts than you have, closer to flush. Then I set the mount and sensor a little further back in the honeycomb of the grill.
yes, push them further into the hole and before securing them (with some black silicone on the back side) test your parking sensors by putting it in reverse...also play with the up and down angle until the sensors read correct-ish. takes some time, but should work once completed. Also some have tried the parking sensor re-calibration procedure, i have not had to do this.
+1. My sensors are completely flush with the front of the Kajo mounts. Note: It is critical that the right honeycombs are used to ensure proper operation of the proximity sensing operation.
Am just wondering the adaptor for sensor still available?
can I buy one pair from you?
please advise
ken
Originally Posted by Meister_Kajo
Hello friends, have just met my friend and this informed me that he can print adapter again. This gives access to the 3d printer again.
If you want to have some and interest, please contact me.
I am wondering if the grill can be mounted without these sensors. Does a P7 have these sensors? Has anyone successfully mounted the grill without the sensors or is this too difficult to overcome? Is trying to work around the grill sensors like trying to undo the rear spoiler up at 70 down at 50 program that seems impossible to overcome?
