P 7 Bumper-less Grille Installed
Old 01-28-2020, 09:13 AM
dsprague27's Avatar
Thanks @Unhingd !
  #502
Old 01-29-2020, 06:48 AM
Row_ca's Avatar
Originally Posted by Unhingd
PM sent.
Unhingd, in the same boat interested in the P7 grill, not sure if I can receive PMs yet (new user, brand new owner) - but any help would be appreciated.
  #503
Old 01-31-2020, 10:36 AM
K00S's Avatar
Hey guys, new user, I have had my F-type for about a year now and now that its in the shop seems like a perfectly good time to change the grille. If/when i am able to PM I am going to reach out to Unhingd and Meister Kajo. Hopefully you are able to help me out. Appreciate all of your work on this thread
  #504
Old 02-01-2020, 01:44 AM
Meister_Kajo's Avatar
First you need the two parts of the P7 grill.
If you have ordered or received them, then write me a message about parking sensor adapters.
greetings
  #505
Old 02-01-2020, 07:05 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
I’ll PM you regarding the parts.
  #506
Old 02-09-2020, 07:05 AM
jleuz1's Avatar
Default 2021 Grille
I may be late on this
Note sensor mounts
but I just noticed the 2021 Grille has no bumper and has sensor mounts.
  #507
Old 02-09-2020, 02:57 PM
Unhingd's Avatar
Note sensor mounts
That grille and surround will not fit the older cars.
jleuz1 (02-10-2020)
  #508
Old 02-11-2020, 07:52 AM
Jaguar1611's Avatar
Originally Posted by eglisau619
Finally did it! Thanks to @Meister_Kajo for the Adapters from the 3D printer! Also did the SVR hood vents and some paint jobs from white to black...
Where did you get those SVR hood vents? I wonder if they could replace the ones I have on the S?
  #509
Old 02-11-2020, 01:35 PM
powerhouse's Avatar
Note sensor mounts
Prefer my own, them front lights from head on the facelift , not so bad but side view there just wrong
  #510
Old 02-12-2020, 02:28 PM
Unhingd's Avatar
it’ll fit on an AWD S
Jaguar1611 (02-12-2020)
  #511
Old 02-28-2020, 03:30 PM
devmen's Avatar
So I'm having the P7 parts installed by a body shop, and they mentioned that they have to drill into a bumper to make the grille fit. Did everyone else have to do it? It won't show anything in the front because the surround will cover it up. Also, are there concerns that removing the foam in back will expose the internals to bad stuff? e.g. rocks
  #512
Old 02-28-2020, 03:35 PM
Chawumba's Avatar
I don't recall having to drill, but what it appears they want to do shouldn't be a problem. Foam has to go, I don't think grill can fit with foam on.
  #513
Old 02-28-2020, 05:44 PM
gg2684's Avatar
Does anyone have photos or a graphic that shows the fasteners that need to be removed to get the front end off - I am planning to do my P7 grill in the spring and, although Im sure I can figure it out, I would be appreciative for any help getting up the learning curve. Thanks.
  #514
Old 02-28-2020, 06:16 PM
evilftypedw's Avatar
I do remember having to drill a hole to fit it to the bumper but it was totally out of sight. You should not have any issues removing the foam.
  #515
Old 02-28-2020, 07:01 PM
devmen's Avatar
Awesome, now I feel like an *** for being so hard on the body shop ("please don't drill anything, it should just fit"). The second question to touch on is actually the consequences of removing the foam. I know you have to remove it, but does that expose alot of rocks and stuff to the engine bay/radiator etc
  #516
Old 02-28-2020, 09:48 PM
Unhingd's Avatar
No drilling was necessary on my installation.
The foam only covers the cross beam that sits right behind it. It served no purpose other than to absorb energy if the deleted bumper bar got tapped.
  #517
Old 03-05-2020, 02:14 PM
Unhingd's Avatar
Default Urgent: Need a spare Front Tow Hook
I have taken a long look time pondering how to install a tow hook with the P7 bumper and have found a machine shop that can carve an OEM hook (using the reverse threaded end )into accepting a billet track hook. If anyone has a spare OEM hook they can donate to the prototype project, please PM me.
  #518
Old 03-06-2020, 08:12 AM
Guardian's Avatar
Question:
having only center section (mesh) of P7 grill will it be possible to install it onto non-P7 surrounding frame (of course modified with blanked side holes)?
  #519
Old 03-07-2020, 01:00 PM
Unhingd's Avatar
Originally Posted by Guardian
Question:
I can’t remember if the plastic tabs of the P7 grille will mate up with the OEM surround. That said, except for the bumper cutouts on each side, the two surrounds have the identical shape, so even though you might have to trim off some of the tabs, you should be able to quite easily bond the P7 Grille to the OEM surround. You’ll be filling in the surround cutouts anyway.
Deogee (03-15-2020)
  #520
Old 03-07-2020, 04:01 PM
Guardian's Avatar
Great, thanks for the reply
Quick Reply: P 7 Bumper-less Grille Installed
