P 7 Bumper-less Grille Installed
#561
#562
#563
Yes...I know that there is NO calibration for the sensors, or a way to "re-orient them" to different position. All of the Ultrasonic inputs received from the sensors are sent to the PACM (Park Assist Control Module), which then communicates with the Infotainment system via audible warnings through the speakers. No adjustments, as they are pre-set to give a detection tone at 1000 mm and a continuous tone at 500 mm.
#566
I'd definitely be interested - are there compatibility issues between models and years? I've got a 20 SVR - I don't know enough about the part numbers or if anything changed. If it would would work, I'll PM you.
#570
Here are the part #s: Grille: T2R18751
Surround: White - T2R18755 or Grey - T2R18756
The previously known sources seem to have dried up. You will need to hunt for yourself. When you do find a source, they may ask for a P7 VIN. Ftyperegistry may be able to assist you with that.
CB1973 (10-10-2021)
#571
#572
The following 3 users liked this post by gg2684:
#573
yes, it is possible. I purchased the eBay carbon surround (and the P7 which I painted black- just really wanted carbon but needed a back up plan) and it works. The non-oem surround is totally different and doesn’t have factory slots for the tabs etc. there was quite a bit of fabrication to make it work correctly and look as intended but it can in fact be done. Now on to finally ordering the Koshi carbon splitter and side wings to round out the look…
#575
meister_kajo, do you still have any of the p7 grill sensor holders made and available for sale? new to the group, thanks.
#576
DPelletier (08-06-2021)
#578
I red thru the whole thread and the best idea I have is radical - what about 3D print, or CNC machine the whole grill with sensor cutouts and space the mesh design in a way that it will accommodate the tow hook. And also make a Euro numberplate holder integrated to the grill.
I think I would be able to do that...
Can anybody please tell me, if the mesh grill is flat or rounded like a sphere? I mean the whole piece, not individual honeycomb.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
