P 7 Bumper-less Grille Installed
Old 10-15-2016, 02:46 AM
Meister_Kajo's Avatar
Thanks polaris...
i consider about this 5.25" space for the license plate.
In germany you have to fix a front license plate.
The breath of the plate is 4,33" and i hope i can fix it between the bottom part of the surround and the bottom of the emblem...an it looks good...
  #62
Old 10-15-2016, 07:20 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Originally Posted by Meister_Kajo
Thanks polaris...
I think you will find this to be an easier and better looking solution:sto'Nsho
  #63
Old 10-15-2016, 10:13 AM
Well i think this solution destroys the front lip.
My plate is 15.7" x 4.33"
I think it looks better on the grill between the surround an the emblem, but flavors are different...
I' ll see it, if i'll have the grill and try it...
  #64
Old 10-15-2016, 10:16 AM
...destroys the optic of the frontlip...
DFW (10-22-2016)
  #65
Old 10-15-2016, 06:29 PM
Unhingd's Avatar
The stoNsho gets mounted to an existing bolt under the splitter, so no parts are damaged. My plate is 21"x5" and the stoNsho accommodates any size. You will just need to find a plate frame that fits your plate. Also, if you mount the plate over any part of the grille, you will reduce a substantial amount of airflow through the radiator.
  #66
Old 10-15-2016, 06:32 PM
Unhingd's Avatar
I understand. Having an open nose is more important to me.
  #67
Old 10-16-2016, 02:25 AM
But on the original grille the plate is also on the stabilizer...
I mean on the OEM grill the plate in on the grill and its no problem with the airflow...
  #68
Old 10-20-2016, 04:31 PM
DPelletier's Avatar
+1 IMO the plate is an eyesore no matter where it goes.....but it's less objectionable to me lower than in front of the grill.
Dave
  #69
Old 10-21-2016, 02:12 AM
I' m not thinking the plate is too bad in the front of the grill.
Well the best thing is without a plate, or the plate between the grill an the front lip, but is this possible to handle this...?
  #70
Old 10-21-2016, 02:15 AM
  #71
Old 10-21-2016, 08:37 AM
IRRBrogue's Avatar
Do you guys really get stopped for no front plate? Tennessee is an NFLP state, No front license plate. So I don't have that problem. I have visited my daughter in Austin, Texas twice, and see a lot of cars with no front plate, even though that is a front plate state.
  #72
Old 10-21-2016, 09:34 AM
DJS's Avatar
DJS
DJS is online now
Received 2,106 Likes on 1,406 Posts
This has been discussed many times. Many of us run without front plates. In MA, we used to have only rear plates (which have green letters.) Now we're front and back, with red letters. But if you have an old green plate, you can still use it.
I got new plates with the Jag (two red plates, all you can get new now), but I only put the front plate on for state inspection. Nobody has ever taken an interest in only having a rear red plate. I was nervous for the first year every time I saw a cruiser, but no one seems to care around here.
Some have mentioned that their meter maids are aggressive in ticketing cars without a front plate.
  #73
Old 10-21-2016, 10:41 AM
DPelletier's Avatar
Looks are subjective but the best looking set up I've seen so far is Polaris'
I have the Sto N Sho and plan to leave it "sto'd" in the trunk unless I get stopped. They are a quality solution that only takes 0.5 seconds to remove and install.
Dave
  #74
Old 10-21-2016, 01:20 PM
IRRBrogue's Avatar
I did get stopped in OH years ago, in a Lincoln Continental. I did not have a front plate, but had it in the car to show the officer. I told him I had moved from another state (true) and did not yet have a front plate bracket. No ticket for the plate, but I still got the speeding ticket.
  #75
Old 10-21-2016, 04:18 PM
Unhingd's Avatar
In MD: YES, we get stopped and fined.
  #76
Old 10-22-2016, 08:29 PM
DFW's Avatar
DFW
DFW is offline
Texas is a front-plate state, but we consider it more a suggestion than a requirement.
The following 2 users liked this post by DFW:
IRRBrogue (10-23-2016), James Tootle (10-22-2016)
  #77
Old 12-12-2016, 08:26 PM
luanbai's Avatar
Is there any way to replicate this look without buying a new mesh grille? I have the vision package with the sensor so it's going to be tough to get the sensors to have the same effect I feel.
  #78
Old 12-12-2016, 10:04 PM
IRRBrogue's Avatar
Not really. The stock grille is two pieces, above and below the center bar.
  #79
Old 12-15-2016, 03:40 AM
fstopst's Avatar
Dave
How difficult is it to install the stoNgo base on to the underside of the bumper? Have a feeling i'm gonna need one of these around where I live lol
  #80
Old 12-15-2016, 08:32 AM
Unhingd's Avatar
Takes a wrench and 1-2 minutes of your time. Involves removing one bolt and screwing a longer one back in with the mounting base.
Quick Reply: P 7 Bumper-less Grille Installed
