P300 one year later, second topspeed attempt.
So I post again the first attempt we did.
..who beats our topspeed of 255kmh in a P300 .. ..where you legally can... :P
Last year, on a 'no limit' highway in Germany, we were 'ahead-of-the-game' after driving along roadworks respecting the 80kmh speedlimit.
Ofcourse you then upset people behind you, but we did have a complete empty road ahead for about 5 kms...
Just run-in, about 3100 km . Rev limiter cuts in at 249kmh :
Again, a year later, more then 16.500 km covered, so well run in.. .. no rev limiter !
The following 2 users liked this post by Dan_NL:
BruceTheQuail (08-24-2019),
Queen and Country (08-28-2019)
https://youtu.be/FUuI6idgtZo
https://youtu.be/b6Ts2tsFBVA
Well, I had a Renault Supercing 1.4 GT Turbo in 1987. A 3 door hatchback with just 120Hp, frontwheel drive..
It did 205kmh on a straight, after a while.. ..in 1987..
It was less heavy [ around 1200Kg me included ], but still. Thirty years on and 300pk ; why not 250..
We were amazed ti continued pulling at 255 . Some day we'll test how fast it really goes, after a while.
We did sense every 10kmh more beyond 230 was squezing it..
xrix4096 (08-25-2019)
Rolling resistance through the wheel bearings would result in no more than 4 lbs of resistive force on a 4000 lb car. Rolling resistance for tires will average about 1lb for every 100 lbs of weight on a smooth surface depending on tire inflation, but could be significantly more on a rough surface at speed. So yes, available hp for speed is definitely impacted by vehicle weight but how significant compared to aerodynamic drag is something for which I’m too lazy to calculate right now. Besides, I can’t seem to find the coefficient of drag for the F-Type.
The drag is quite unpredictable. There was a TV show once about KAHN, he wanted a certain model of spoiler but had no budget to test it.
So they build it anyway. Result was that the front wheels came off the ground at higher speed.. ..it didn't stay on long...
Anyway, I did raise tire pressure from the adviced 2.5 all 4's to 3.0 all 4's . Noticed my tires were wearing on the outsides mostly,
didn't do that many doughnuts..
xrix4096 (08-27-2019)
Have mine just over 16 months now and the engine is well run in now, seems to have got more responsive, drove a 2019 model and seems sluggish in comparison, looks like this engine gets better with age.
The 2.0 turbo has plenty of power increasing options, see this article.
A 2.0-litre turbo four, paired with a six-speed sequential transmission, and producing 521 hp and 372 lb-ft of torque, enabling the Chinese concept to hit 0-62 mph in 4.4 seconds and a top speed of 193 mph.
https://carbuzz.com/news/jaguar-xe-s...mK97og3C4sxbBA
Fastest my V6 S able to hit with the top up was 170, and after 160 it took a long long time to get there. It may have a little bit more left in in, but not much, Also not too many place you can do that safely, and even so the thought of passing a cop is pretty scary. Anyone else get anything better with their V6? top down It didn't get past 164 but it did not feel stable after 155.
The I4, V6, V6S and V8 all have different final drive ratios (3.55, 3.15, 3.31, & 2.56 respectively). The AT and MT have different top gear ratios as well.
