P300 Rattle From Engine Timing Chain Area
Don't own an F-Type anymore. But tried to help another forum member on FFRR forum :
SITUATION:
A rattle noise may be evident from the engine compartment and/or the engine MIL (Malfunction Indicator
Lamp) may be illuminated on the Instrument Cluster. Upon further investigation, Diagnostic Trouble Codes
(DTC) P052A-00, P0011-71, and/or P000A-00 are found stored in the Powertrain Control Module (PCM).
CAUSE:
This may be caused by a Variable Camshaft Timing (VCT) unit internal seal that is below specification.
ACTION:
Should a customer express this concern, follow the Workshop Procedure below.
https://static.nhtsa.gov/odi/tsbs/2018/ ... 4-9999.pdf
SITUATION:
CAUSE:
ACTION:
DJS (12-30-2021)
bizspeed
US Lower Atlantic
08-04-2015 10:56 PM
