P7 Grille Lockdown Project Finally Done
Old 06-23-2020, 03:13 PM
wurldfamuz's Avatar
Default P7 Grille Lockdown Project Finally Done
Thanks Unhinged and itismejoshy for the help and Meister_Kajo for the pdc adapters.
The following 5 users liked this post by wurldfamuz:
Mbourne (06-23-2020), Paul champagne (06-24-2020), Robc2562 (06-24-2020), STMPY (06-23-2020), Tork Monster (06-28-2020)
Old 06-23-2020, 03:29 PM
gg2684's Avatar
top work sir! I’m actually saving mine for a fall project - need to heal up a bit after surgery so I’ve been confined to smaller and less invasive projects but nice to see another one complete.
Old 06-23-2020, 03:49 PM
Therock88's Avatar
Looks Great! Good job.....
DC
Old 06-23-2020, 04:51 PM
Hell Cat's Avatar
Wow that looks clean. How much of a pain would you rate the install?
wurldfamuz (06-24-2020)
Old 06-23-2020, 06:46 PM
Mbourne's Avatar
Looks fantastic. Had not seen it on a white car yet and was wondering what the look would be.
Old 06-23-2020, 10:22 PM
madmax1911's Avatar
Wow, that really looks good. I need to get off my a$$ and get the parts ordered for mine.
Old 06-24-2020, 01:47 AM
bcbruno's Avatar
Looks amazing.
Where the license plate will be place? it's ok by law to don't use it on front?
Old 06-24-2020, 02:01 AM
wurldfamuz's Avatar
Originally Posted by bcbruno
Looks amazing.
front license plate?? what is that?
Old 06-24-2020, 02:40 AM
wurldfamuz's Avatar
not too bad, i'd give difficulty level at 6. just alot of removing screws and you definitely need another pair of hands to help.
It also took me longer to complete the work than it should've since I kept on changing the color I wanted the grille surround. I initially sprayed it with satin black but after a couple of days it wasn't doing it for me so took bumper back off and sprayed it with gloss black but again after a few days, I wasn't happy I never wanted glossy don't know why I even tried it. So I decided to wrap the surround and finally after trying a few different shades of black/drk grey color wraps, decided on the go with color you see (for now), it was the closest shade of black or dark grey I had in my head that I wanted.
Also did the side vents and part of the hood vents the same color as the grille surround.
Old 06-24-2020, 02:53 AM
JacksonvilleJag's Avatar
That looks great! Of course we all already know that. Problem is, the more of them I see, the more I can't get it out of my head. What are we looking at for total costs on average for this across the group?
bcbruno - Some states in the US require front plates, and some don't.
Old 06-24-2020, 03:29 AM
scm's Avatar
scm
scm is offline
Received 1,460 Likes on 1,105 Posts
Something the unenlightened powers that be in the UK insist upon.
Old 06-24-2020, 05:59 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
The Sto’N’Sho bracket works when a front plate is absolutely needed, and takes 2 seconds to remove by pulling a pin when not.
Old 06-24-2020, 06:05 PM
STMPY's Avatar
Where did you get that plate? Is that a legal front plate?
Old 06-24-2020, 06:18 PM
Unhingd's Avatar
licenseplates.tv.
No, not technically legal, but I’ve had the popo look at them closely a couple times to confirm the same tag# on the rear plate. They do contain the proper info (tag number and state of registration) and the font is larger than state issue.
The only risk is a $50 fine.
Old 06-24-2020, 07:26 PM
Hell Cat's Avatar
That grille looks so clean
I may need to look into this further
Old 06-24-2020, 08:07 PM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
licenseplates.tv.
Hey Lance, can you measure for me the gap from the bottom edge of your plate to the ground?
I'm thinking of getting a P7 grille and a StowNShow (no other easy and clean way I can see of fitting a number plate to a P7 grille) but there are stoopid rules here about this clearance.
I think the minimum height/gap is 30 cm / 300 mm but I'm still trying to find the rule, and if your gap is less than whatever that rule says then I am screwed (add 5 mm for your lower front end but subtract 5 mm for my skinnier number plate so it's a wash).
Old 06-24-2020, 08:44 PM
Unhingd's Avatar
Nowhere in the right time zone. 160mm to the bottom of my plate frame. You’d have to either use a tow hook plate bracket (offset plates look bad on an F-Type) or mount the plate directly to the grille honeycombs with tie wraps.
OzXFR (06-24-2020)
Old 06-24-2020, 10:09 PM
OzXFR's Avatar
Thanks for that.
I found the rule and it is 300 mm, so I'm screwed.
Old 06-24-2020, 11:17 PM
Paul champagne's Avatar
I never get tired of looking at that. That really is the way the car should have been from the start.
Old 06-26-2020, 09:21 AM
Stuart Satter's Avatar
Where did you buy the grill? Or did you make it?
Quick Reply: P7 Grille Lockdown Project Finally Done
