Paint blemish from dirt
I have a white 2015 F Type S V8 that has small specs of dirt that seem to be embedded into the paint just in front of the rear tires on both sides. I have tried to wash it and tried to scrape them off with my finger nail as well as clay bar them but they seem to be embedded in the paint. I assume it's normal for a white car that's 7 years old since it only has 30k miles and hasn't been abused. I want to ceramic coat the car myself and would like to get these blemishes out before I do that. How would I go about getting them out? Or can someone point me in the right direction?
I used chemical guys light/medium duty clay bar with the lube spray for it. Link is below on Amazon. Should I use a different one?
https://www.amazon.com/Chemical-Guys...s%2C642&sr=8-4
you can try going up to the heavy clay bar, but I’m surprised the current isn’t working as that’s the one I tend to use. Regardless you’ll have to correct the paint prior to coating the car and polishing will remove everything more efficiently.
Actually...It may look like "dirt", but is likely some other fallout or contaminants. Also, on lighter cars you can more readily see the iron deposits from the brakes (dust and particles that stick to the car).
I periodically treat my car (also white) with Iron X Fallout Remover (or similar). You spray it on when you are about to wash it and let it dwell for a bit, and it will change color (usually purple) as it works...Then just rinse off and wash as normal, or clay bar or whatever else your correction process will be. I would suggest that before getting too aggressive with abrasives or clay (also an abrasive).
ALSO NOTE: These Fallout removers are the WORST smelling crap ever...I am not kidding. if you use it, you will see what I mean. Horrible smelling...Like a pile of feces on a rotting carcass bad
I also had much of my car covered in PPF and I also Ceramic coated, so it is pretty well protected.
Example below. (No affiliation BTW...Just trying to help)
Good luck,
DC
Good luck,
DC
The following 2 users liked this post by Therock88:
BruceTheQuail (01-09-2022),
dbleoh7 (01-09-2022)
It's likely not dirt or contaminants but likely paint damage. Some of the 2015 paint jobs were on the light side and many 2015 cars have that (specifically the white cars). Other option is to look at Mother's R3:
https://mothers.com/products/r3-raci...-remover-09224
It removes just about anything that can be removed (beyond race rubber).
https://youtu.be/a4WdscajaT4
Good luck,
DC
Good luck,
DC
DC
If indeed, you DO decide the paint is chipped from debris, I can recommend Dr Colorchip.
https://drcolorchip.com/
My car had similar issues in front of both rear wheels. I am pretty sure it is clear coat damage from debris flying off the wheels and/or then bouncing off the road and hitting the car. To address the issue on my car I very carefully tried scratch remover followed by polish. It removed most of the damage (to a level far, far less noticeable) but I was afraid of removing too much clear coat to completely fix it.
My vote is iron as well, the ironX works wonders but smells horrific.
I would be very careful about ceramic coating the car myself, I had a terrible experience with the Carpro product and wouldnt try again. I have been getting awesome results through good quality waxes, once a year clay and base wax, maintained by a spray on. I use Polish Angel products which are super easy and virtually effort free (also no silicon), though I understand there are plenty of other good ones. The less rubbing, the less static, the less static, the less dust.
I just wash the car 2 bucket method and spray it down while still wet and use waffle weave microfiber towels to dry (the rag company 70/30 Korean blend). This method probably works well because my car is also white so there’s minimal streaking, can’t imagine it being great for a darker vehicle. The beading, sheeting, ease of cleaning and use has been spectacular though. It really makes protecting the car so easy can’t imagine the longevity to be the greatest using this method and product, but I can say I’ve gone 2 weeks between washes and it was still clearly on the surface.
