I'm dropping off my stock muffler to have the tips ceramic coated. I'm thinking of having the muffler body coated black as well to help hide it better. Has anyone done this and had any issues with the muffler or tips melting any of the rear plastic? I've seen plenty of the coated tips and the plastic seems to hold up fine but I'm less sure of the muffler.
I did mine (myself) with high temp ceramic paint (Satin black) and I am happy with the outcome, and no issues with heating/melting/or anything else.
I removed the muffler unit and had the tips replaced with larger carbon/black tips and painted the muffler belly and all the plumbing behind the rear valence so it blends in with Ceramic Duplicolor - Masked it off so only the desired pieces were painted and didnt have overspray all over - even if no one could tell, but it looks great and holds up well and allows the belly portion visible under the rear to blend nicely. The paint will use heat to cure fully so expect a smell for the first few cycles of driving.
I didn't find that in your DIY guide. Did you do it while on the car? Could you give us a quick breakdown?
Vik
Hi....Yes, I did both on the car. You could certainly take the rear diffuser/bumper off or apart, but honestly, there is plenty of room to mask it off and spray it on the car. I masked off the openings, and covered the car with a plastic drop cloth to prevent overspray. I also used a laser thermometer on several occasions after hard or long drives to get a max temperature, and I do not think it ever exceeded ~300 degrees, so any engine/caliper/or exhaust paint will work. I wanted semi-gloss / satin as I just do not care for flat black. I ordered some high temp semi-gloss or satin (cannot recall) ceramic paint online. After masking it all off. I just carefully sprayed the tips, and the muffler with about 4 coats. Only caution is to be careful how you spray, so you do not get excess build up on the edge of the tips while you are trying to spray the back parts through the openings.
I like the silver on the inside of the tips, I was worried it wouldn’t blend and didn’t like seeing chrome with the black pack on all the other trim, but they look great. Where did you find them and what are the dimensions? I think mine are like 5-7 mm wider than factory.
This was a project that i don't advice due the work and because you need to offset the centerline too much. The costs are higher than buy a aftermarket muffler, but i really wanted keep stock tone and muffler.
Dimensions are 114mm OD, 102mm ID and on muffler connection 2.5" i believe, similar to my F-type V6 exhaust. Now is everything black matt. I will take better pictures later! I got them here on Dutch exhaust shop, a bit expensive due the real carbon!
All black, size is almost unnoticed (except for the smoke and noise )
