Painting Rear Diffuser
Made an appointment to have my rear diffuser painted Firesand to match as in the design pack. I really like the look and got a quote from a reputable body shop to have it painted and cleared for $275 USD total. I think it's a decent price since they are going to have the car for 3 days and remove it to paint it. I'll post up pictures when completed.
I really want to see pic's of your car out in the sun, maybe with the new BRG SVR grocery getter in the back ground
Hell, the cars going to be in the shop for the rear diffuser already, see if they can do the calipers for you ?
DC
JacksonvilleJag (07-28-2020)
That she is, it's a magnificent beast. I asked them if they could do the calipers, but they won't use the G2 paint I already have. They want to remove the calipers, clean, paint reinstall, and of course brake bleed. Costs went way up, and like I said, I already have the G2.
I understand their position completely, I just don't want to spend that much to do the calipers when I already have the Firesand G2 that I paid for, and I'm good with the results you get from the G2. I'll get to it eventually. I really like the way the rear end looks with the quad pipes and design pack. Excited to get it done.
I believe other then a removal and stripping of the calipers so the can be powered coated you won't find a better durable paint anywhere that's color matched as well.
That just my experience.
Make sure you post pictures when completed.
I will be excited to see the rear diffuser the color of the car! As for the G2 paint, I think you will be very happy with the look as well as the quality.
Agreed, like most things; you can spend as little or as much as you want. I have removed and re-sprayed and powder coated calipers and they looked amazing - I used to do car shows and details are important especially when you’re taking wheels off for display, but I eventually tried G2 on one of my daily drivers and was pleasantly surprised. Easy to use, levels nicely, but like all paint work, the prep is about 90% of the work and will show in the results. I have a VW R32 with the signature blue calipers and they are fading- I just recently bought a G2 kit for it and the color test I did was spot on - I’m sure they will look factory fresh when done. Also planning to do the school bus (wrangler unlimited) with G2 this fall; although the truck is white and the calipers will match, but thinking it may take two applications. Good luck and don’t fret about your choice.
Each pass I used a clean rag to gage how clean they were.
This method worked for me. I also used multiple size paint brushes to get into tighter spaces and not get paint where it didn't belong.
Masked areas the could be masked.
I personally think its a great product and anyone that has seen my car since was amazed and thought the car came that way.
Been to about 5 or six cruise nights or shows.
One other thing to note is the rear caliper castings are not as smooth so you will never achieve complete flat paint on those and the fronts
are better but again not completely smooth.
I am completely satisfied with my results. 1 kit will do all 4 calipers easy 3 coats with some left over.
