Today while doing the front spat’s I also replaced the scratched park push button. I ordered both the Jaguar and Land Rover buttons. The Jag in gray and the LR more silver. Super easy to change with a fine screw driver to pop the tabs on the top.
I liked the Land Rover better as it matches the surround below.
and there is the new start button from last weeks two minute project
And if you want it to look the same ten years from now, pop it off again and spray it with several coats of plastic-adherent polyurethane. Easy, and the resuts are perfect. The stop/start button can be treated in exactly the same way.
